Hello,
I am new to Geoserver so any help would be appreciated. I am trying to build an app that utilizes raster dataI have ingested into my PostgreSQL/PostGIS database. The error occurs when trying to make the PostGIS raster data store. However, I have previously created a postgis vector data store from this same data base. The error on the web interface says “Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:glc.postgis.xml and hints null”.
However within the geoserver log we find that we have a connection error.
2015-06-29 09:02:30,681 WARN [data.jdbc] - Could not acquire A BDCP connection pool.:org.geotools.data.DataSourceException: Connection pool improperly set up: Cannot create PoolableConnectionFactory (Connection refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.)
I know that I have the connection xml defined properly. I am following the following documentation.
http://docs.geoserver.org/2.5.x/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
