[Geoserver-users] (no subject)
Hello list,
I have a problem with one of my layers I recently published. When I send the WMS GetMap request, I get the correct image but meanwhile I also get an error in the log-file.
Request:
http://xxxx:8080/geoserver/wms?LAYERS=thematic_maps%3Axxxx&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=1864086.4986679,6057703.736978,1881213.1703159,6071233.0909826&WIDTH=1792&HEIGHT=1416
Error:
2015-09-24 08:39:57,489 ERROR [geoserver.ows] -
java.lang.IllegalArgumentException: Requested bounding box contains wrongnumber of coordinates (should have 4): 1
at org.geoserver.wfs.kvp.BBoxKvpParser.parse(BBoxKvpParser.java:34)
at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:421)
at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1469)
at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1465)
at org.geoserver.ows.Dispatcher.init(Dispatcher.java:322)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:245)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
Any idea where that comes from? Should I create Bug report in JIRA?
Best regards, Niko
version: 2.7.2, Oracle Corporation: 1.7.0_55 (Java HotSpot™ 64-Bit Server VM), running on RHEL 6
Hi Nikolaus,
this is quite strange, the bbox seems ok, and yet GeoServer seems to think it only
has one ordinate, instead of four.
Is that a standard GeoServer downloaded from geoserver.org? Do you have any extra
plugins?
What default national language is the server using?
On Thu, Sep 24, 2015 at 4:33 PM, Nikolaus Pruzsinszky <n.pru@anonymised.com.5804…> wrote:
Hello list,
Request:
Error:
Best regards, Niko
Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
Get real-time metrics from all of your servers, apps and tools
in one place.
SourceForge users - Click here to start your Free Trial of Datadog now!
http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
yes, it is a standard GeoServer, I have installed following extensions:
GDAL
Image Pyramid
JPEG2K
Control Flow
CSS Styling
Monitor (Core)
Importer (Core)
Printing
CSW
WPS
The GUI uses german.
The funny thing is, that we have lots of other layers published on this server (sources are rasters as well as all sorts of vector geometries) and I have never seen this error before.
Cheers, Niko
Andrea Aime <andrea.aime@anonymised.com> schreibt:
Hi Nikolaus,
think it only
Is that a standard GeoServer downloaded from [ http://geoserver.org
]geoserver.org? Do you have any extra
plugins?
On Thu, Sep 24, 2015 at 4:33 PM, Nikolaus Pruzsinszky <[
mailto:n.pru@anonymised.com ]n.pru@anonymised.com> wrote:
Hello list,
Request:
]http://xxxx:8080/geoserver/wms?LAYERS=thematic_maps%3Axxxx&format=image%2Fpng&transparent=TRUE&service=WMS&version=1.1.1&request=GetMap&styles=&srs=EPSG%3A900913&bbox=1864086.4986679,6057703.736978,1881213.1703159
,6071233.0909826&width=1792&height=1416
Error:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best regards, Niko
in one place.
[ http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
]http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
[ mailto:Geoserver-users@lists.sourceforge.net
]Geoserver-users@lists.sourceforge.net
[ https://lists.sourceforge.net/lists/listinfo/geoserver-users
]https://lists.sourceforge.net/lists/listinfo/geoserver-users
[ http://goo.gl/it488V ]http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
[ http://www.geo-solutions.it ]http://www.geo-solutions.it
[ http://twitter.com/geosolutions_it
]http://twitter.com/geosolutions_it
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Sep 25, 2015 at 7:52 AM, Nikolaus Pruzsinszky <n.pru@anonymised.com>
wrote:
Hi Andrea,
GDAL
Image Pyramid
JPEG2K
Control Flow
CSS Styling
Monitor (Core)
Importer (Core)
Printing
CSW
WPS
Wow, lots of them.
Hum... and the error happens only for this particular layer?
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry,
we managed to solve the problem, the request that was meant to be sent by some monitoring tool was corrupt. Mixing up spaces with something else.
Thank you anyway, Niko
On Fri, Sep 25, 2015 at 7:52 AM, Nikolaus Pruzsinszky <[
Hi Andrea,
GDAL
Image Pyramid
JPEG2K
Control Flow
CSS Styling
Monitor (Core)
Importer (Core)
Printing
CSW
WPS
Wow, lots of them.
Hum… and the error happens only for this particular layer?
Ing. Andrea Aime
@geowolf
Technical Lead
D.Lgs. 196/2003.
