On Thu, Oct 22, 2015 at 8:55 AM, Chris Brown <chris@anonymised.com0…> wrote:
Hi Anrdea,
Sure, I would be happy to give that a try, please let me know once it hits the nightlies. It might take me a few days to test, because to test that volume we need to clone our production server with all the data onto staging which is a big of an exercise.
Chris
On 21 October 2015 at 02:22, Andrea Aime <andrea.aime@anonymised.com> wrote:
Chris Brown
MangoMap
On Tue, Oct 20, 2015 at 6:10 PM, Chris Brown <chris@anonymised.com> wrote:
We’ve just installed JDBCConfig on a large GeoServer deployment with about 40,000 layers. The install web smoothly but we’re seeing some very strange behaviour when we do any updates such as adding layers via the REST API.
All such requests hang the server for around 25 minutes. Turning on the debugging log, it looks like some process is looping over every single layer in the catalog. The output in the log looks like this:
If anyone has any ideas about what we may have done wrong or any ideas what might be causing this it would be hugely appreciated. The closest thing I could find to this issue was this: http://comments.gmane.org/gmane.comp.gis.geoserver.user/41076
You’re not doing anything wrong, it’s just that the core of GeoServer still has many bits of code that are written
with an in memory catalog in mind, JDBCConfig work included some examples spread out in the code
base that serve as examples of how things should be done to work against a in dbms catalog,
but the migration is not complete, there are still bits of code here and there that load everything
there is to perform some in memory check, that could be replaced with a well written query
loading only the bits that are actually needed.
One year ago we worked on fixing the biggest offenders in the UI and some core modules,
leaving out the integrated GWC as the biggest outstanding offender.
Guess what, I’m working on a patch to address some of the issues right now, which might or
might not address what you’re seeing, it should be landing on the development series
next week.
I’m not saying this will remove all “linear scans” that are in the codebase, but it should help in some cases.
Let me know if you’re interested in testing that out, if so I’ll ping you when I commit it.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
