I tried (with no success) to force Geoserver to serve tables without geometric columns from Postgres in order to get simple csv files. Has anybody any experience about that ?
Laurent
Laurent
I've had no problem serving tables without geometric columns from PostGIS. Are you using PostGIS or plain PostgreSQL?
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Mar 27, 2009, at 9:53 AM, les Pierre wrote:
Laurent
Geoserver-users mailing list
2009/3/27 ajs6f <ajs6f@anonymised.com>
I’ve had no problem serving tables without geometric columns from
PostGIS, but when I try to create the new entity , Geoserver (1.7.2) complains there not geographic matter to play with.
Laurent
Are you getting a specific exception from the J2EE container logs?
On Mar 27, 2009, at 10:13 AM, les Pierre wrote:
PostGIS. Are you using PostGIS or plain PostgreSQL?PostGIS, but when I try to create the new entity , Geoserver (1.7.2) complains there not geographic matter to play with.
Laurent
les Pierre ha scritto:
2009/3/27 ajs6f <ajs6f@anonymised.com <mailto:ajs6f@anonymised.com>>
Hmmm.... can you give us the exact error message and what you
are doing to configure the layer? To the best of my knowledge
it's really sufficient to force in a made up lat/lon bbox to
keep the configuration happy.
Andrea Aime
OpenGeo - http://opengeo.org
