[Geoserver-users] NPE in WFS GetFeature request. Problem with data permissions
I found a problem with WFS GetFeature requests returning a NPE (see exception below). These conditions must occur at the same time for the problem to appear:
  • There must be a data rule that allows an entire workspace only for a specific role (for example, sf.*.r: myrole).
  • There must be a data rule that allows a single layer in that workspace for any role (sf.roads.r: *).
  • The first WFS request that arrives to the server must come from a user that doesn’t have the role described in the first condition.
You can reproduce it with the following data_dir (tested on GeoServer 2.8.1): https://www.dropbox.com/s/gdkmht7hsipgcg9/data_dir.tar.gz?dl=0. Performing this request:
curl -X POST “http://localhost:8080/geoserver/wfs” -d @/tmp/payload.xml -H “Content-Type: application/xml; charset=UTF-8”
with this payload.xml:
<wfs:GetFeature xmlns:wfs=“http://www.opengis.net/wfs” service=“WFS” version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”><wfs:Query typeName=“feature:tiger_roads” xmlns:feature="http://www.census.gov"/></wfs:GetFeature>
The problem comes because the XML schema for the WFS request has not been obtained previously and the user that performs the request doesn’t have permissions to see the workspace (even though it can see a specific layer within that workspace). It doesn’t happen after the admin user (or any other user that can see all layers) performs a WFS request and the schema is built successfully.
What I’m trying to do is to secure all layers in a workspace except from one. Am I doing something wrong or is this a bug in GeoServer?
Best regards.
Víctor González
http://geomati.co
I just added an issue to the tracker for this, in case someone wants to follow the progress: https://osgeo-org.atlassian.net/browse/GEOS-7391
Cheers.
2016-01-19 10:12 GMT+01:00 Víctor González <victor.gonzalez@anonymised.com>:
Best regards.
java.lang.NullPointerException
at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.buildSchemaInternal(FeatureTypeSchemaBuilder.java:194)
at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.addApplicationTypes(FeatureTypeSchemaBuilder.java:503)
at org.geoserver.wfs.xml.v1_0_0.WFS.buildSchema(WFS.java:231)
at org.geotools.xml.XSD.getSchema(XSD.java:232)
at org.geotools.xml.SchemaLocator.locateSchema(SchemaLocator.java:96)
at org.geotools.xml.impl.ParserHandler.startElement(ParserHandler.java:404)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:380)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDriver.scanRootElementHook(XMLNSDocumentScannerImpl.java:614)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3135)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:880)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:118)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:642)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:326)
at org.geotools.xml.Parser.parse(Parser.java:240)
at org.geotools.xml.Parser.parse(Parser.java:188)
at org.geoserver.wfs.xml.v1_0_0.WfsXmlReader.read(WfsXmlReader.java:79)
at org.geoserver.ows.Dispatcher.parseRequestXML(Dispatcher.java:1553)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:691)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:265)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Víctor González
http://geomati.co
Víctor González
http://geomati.co
I had a working GeoServer 2.8.1 under Tomcat on Linux that had an error crashing when I tried to view layer groups in the admin interface.
I installed a second copy of GeoServer 2.8.1 under Tomcat at a different URL and copied across the raster data and created the layers I needed.
In the original system, I could view the whole of the UK 1:25k raster data.
Under the new system I get the error below until I zoom to 1:68k.
Any ideas what I am missing.
org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1307)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:1191)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:1157)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1163)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:871)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:850)
at org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:149)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:229)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:219)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:511)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverageInEnvelope(GridCoverageReaderHelper.java:298)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverages(GridCoverageReaderHelper.java:203)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:800)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.paint(GridCoverageRenderer.java:1165)
at org.geotools.renderer.lite.StreamingRenderer$RenderCoverageReaderRequest.execute(StreamingRenderer.java:3414)
at org.geotools.renderer.lite.StreamingRenderer$PainterThread.run(StreamingRenderer.java:3503)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: javax.media.jai.util.ImagingException: All factories fail for the operation “Mosaic”
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1687)
at it.geosolutions.jaiext.ConcurrentOperationRegistry.invokeFactory(ConcurrentOperationRegistry.java:576)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getRendering(RenderedOp.java:888)
at javax.media.jai.RenderedOp$1.getPropertyNames(RenderedOp.java:1791)
at javax.media.jai.PropertyEnvironment.mapDefaults(PropertyEnvironment.java:270)
at javax.media.jai.PropertyEnvironment.getPropertyNames(PropertyEnvironment.java:125)
at javax.media.jai.WritablePropertySourceImpl.addProperties(WritablePropertySourceImpl.java:298)
at javax.media.jai.RenderedOp.createPropertySource(RenderedOp.java:1817)
at javax.media.jai.RenderedOp.setProperty(RenderedOp.java:2034)
at org.geotools.image.ImageWorker.setROI(ImageWorker.java:684)
at org.geotools.image.ImageWorker.mosaic(ImageWorker.java:4359)
at org.geotools.gce.imagemosaic.MergeBehavior$2.process(MergeBehavior.java:149)
at org.geotools.gce.imagemosaic.RasterLayerResponse$Mosaicker.createMosaic(RasterLayerResponse.java:815)
at org.geotools.gce.imagemosaic.RasterLayerResponse$Mosaicker.access$2600(RasterLayerResponse.java:646)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.produce(RasterLayerResponse.java:1027)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.access$3100(RasterLayerResponse.java:846)
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1259)
… 20 more
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor737.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
… 39 more
Caused by: java.lang.IllegalArgumentException: The reference geometry must be either Polygon, MultiPolygon, or a polygonal PreparedGeometry
at javax.media.jai.JAI.createNS(JAI.java:1087)
at javax.media.jai.JAI.create(JAI.java:973)
at org.jaitools.imageutils.ROIGeometry.getAsImage(ROIGeometry.java:474)
at com.sun.media.jai.opimage.MosaicOpImage.(MosaicOpImage.java:374)
at com.sun.media.jai.mlib.MlibMosaicOpImage.(MlibMosaicOpImage.java:49)
at com.sun.media.jai.mlib.MlibMosaicRIF.create(MlibMosaicRIF.java:74)
… 44 more
2016-01-28 16:28:36,268 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:569)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:260)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:132)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
at org.geoserver.wms.GetMap.run(GetMap.java:248)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.GeneratedMethodAccessor878.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy218.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor841.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:309)
Caused by: org.geotools.data.DataSourceException: Unable to create this mosaic
… 3 more
… 20 more
… 39 more
… 44 more
