I was just experimenting with compressed tiff files and ran into a NPE when previewing the layer.
At com.sun.media.jai.util.SunCachedTile in it line 80
Is this a supported configuration?
On Mon, Sep 21, 2015 at 6:41 PM, Alex O'Ree <spyhunter99@anonymised.com> wrote:
At com.sun.media.jai.util.SunCachedTile in it line 80Is this a supported configuration?
Yep, we use it all the time, just hit it a few days ago with a training
class, no problems
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Any pointers on what gdal flags to use that are supported?
I can import the uncompressed geotif no problem. I then compressed it with
gdal_translate -co “COMPRESS=JPEG” input.tif output.tif
and then imported the file as a new data store. It imports but when rendering the layer preview (openlayers) i get nothing to the browser.
The server log has contents like
NPE at com.sun.media.jiautil.SunCachedTiled, line 80
referenced from org.geotools.image.ImageWOrker.writeJPEG(ImageWorke:3664)
using geoserver 2.8RC1 with gdal 1.11.1
On Mon, Sep 21, 2015 at 6:41 PM, Alex O’Ree <spyhunter99@anonymised.com> wrote:
Yep, we use it all the time, just hit it a few days ago with a training class, no problems
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Sep 21, 2015 at 8:14 PM, Alex O'Ree <spyhunter99@anonymised.com> wrote:
None.
gdal_translate -co "COMPRESS=JPEG" input.tif output.tif
Can you do a gdalinfo on that file, and report the version of GeoServer you
are using, along with
whatever extra plugin you might have installed?
Ing. Andrea Aime
@geowolf
Technical Lead
