[Geoserver-users] Null pointer error when adding PostGIS Versioning Datastore
I just grabbed a fresh Geoserver nightly build and trying "Versioning
PostGIS" but I got a null pointer error:
Does any one know what I missed here? I used sample spearfish data from the
build.
form connection params { port=5432, passwd="spearfish",
dbtype="postgis-versioned", host="localhost", version enable all=true, loose
bbox=true, user="spearfish", database="spearfish", wkb enabled=true}
19 Nov 14:18:08 WARN [geoserver.action] - Unable to fetch a list of
FeatureType names from datastore.
java.lang.NullPointerException
  at
org.geotools.data.postgis.VersionedPostgisDataStore.enableVersioning(VersionedPostgisDataStore.java:1013)
  at
org.geotools.data.postgis.VersionedPostgisDataStore.setVersioned(VersionedPostgisDataStore.java:367)
  at
org.geotools.data.postgis.VersionedPostgisDataStoreFactory.createDataStore(VersionedPostgisDataStoreFactory.java:156)
  at org.geotools.data.DataStoreFinder.getDataStore(DataStoreFinder.java:110)
  at
org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:62)
  at
org.vfny.geoserver.util.DataStoreUtils.acquireDataStore(DataStoreUtils.java:51)
  at
org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataStoresEditorAction.java:135)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1054)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at
  at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at
  at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1045)
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
  at org.mortbay.jetty.Server.handle(Server.java:303)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
  at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:735)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:636)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
  at
org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:217)
  at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
View this message in context: http://www.nabble.com/Null-pointer-error-when-adding-PostGIS-Versioning-Datastore-tf4839949.html#a13846952
