[Geoserver-users] NullPointerException with the schema.xml
I've update “geoserver-1.3.0.a” to “geoserver-1.3.3.a.”. Now I have nearly the same Problem. If I add new FeatureType from the Oracle Data Store and shutdown the tomcat and I started the tomcat again.
I get now this error message:
[CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader -
Loading configuration file: /usr/local/tomcat-5.5.12/webapps/geoserver_test/data/featureTypes/and2_BUILDUPAREA/schema.xml
java.lang.NullPointerException
But when I open the schema.xml File I don’t find any errors.
I send the catalina_out as attachment maybe someone can help me?
Thank for your help
Nils
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
catalina_out.txt (8.83 KB)
