[Geoserver-users] "Number of Decimals" - current functionality
Hi List,
I’m trying to better understand the “Number of Decimals” setting that can be found on the Global settings page, and also on a per-layer basis for vector layers.
Because all our data is in British National Grid, we’ve set the global setting to 2 - that’s a precision down to the millimetre, more than enough.
However, during a conversation with one of our users, we realised - what happens to folks using WGS:84 - Lat/Lon to two decimal places is pretty much useless (precise to about 1.1km on the north/south, slightly more so east/west due to our latitude).
So I’ve been testing to see what happens with WFS GetFeature queries using the Layer Preview page:
  • Excel, GeoJSON, CSV, and shapefile all ignore the setting and return as many decimals as they feel like.
  • GML (at least the ones that worked), does honour it.
So my questions:
  • Is it worth considering a setting on a per-EPSG basis? (I know there are a lot of EPSG’s, but I suspect few are interchangeable/used on the same system)
  • Is it supposed to be used only for GML or carried over to the other WFS export formats as well?
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
2014-07-30 13:25 GMT+02:00 Jonathan Moules <
jonathanmoules@anonymised.com>:
- Is it worth considering a setting on a per-EPSG basis? (I know there are
a lot of EPSG's, but I suspect few are interchangeable/used on the same
system)
It would be worth to consider if it is possible to apply the setting on a
per-unit basis. Nevertheless the EPSG CRS you are going to use two decimals
are enough for meters and not for degrees.
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Hi Stefano,
I like the idea of a per-unit basis. Makes much more sense than a per-EPSG basis (which is probably why it didn’t occur to me :wink: ).
I’ve opened a JIRA with the suggestion: http://jira.codehaus.org/browse/GEOS-6615
That done, does anyone have any thoughts on the fact it only seems to affect GML. Is this intentional or a bug?
Jonathan
On 30 July 2014 13:00, Stefano Iacovella <stefano.iacovella@anonymised.com> wrote:
2014-07-30 13:25 GMT+02:00 Jonathan Moules <jonathanmoules@anonymised.com…>:
It would be worth to consider if it is possible to apply the setting on a per-unit basis. Nevertheless the EPSG CRS you are going to use two decimals are enough for meters and not for degrees.
Stefano
41.95581N 12.52854E
