[Geoserver-users] Odd behavior with ArcSDE DataStore
I'm quite new with GeoServer and I'm testing it with ArcSDE 9.2 running a versioned enterprise geodatabase on MS SQL Server 2000. For the time being, I'm primarily interested in testing GeoServer for read-only use of our data (ie., no versioned editing with GeoServer).
I've run into a couple of issues with the two most recent releases of GeoServer, which I'll sum here:
GeoServer 1.6.3: My initial test last week with 1.6.3 had some encouraging results, with a nice stable connection to an ArcSDE DataStore in which I was able to create several FeatureTypes that performed nicely. The DataStore connection used an ArcSDE account that we use for read-only access to most of our layers. The issue that I found was that after the DataStore was created, every time GeoServer was started, it would create a state in our ArcSDE database. This state would create a state lock in ArcSDE that would prevent any other users from reconciling or posting edits. Closing GeoServer would leave this unclosed state, persisting the issue of nobody being able to reconcile or post edits.
GeoServer 1.6.4: I've been unable to create a stable ArcSDE DataStore. When attempting to create a FeatureType, I receive the following error:
GeoServer - Exception
The following exception was thrown:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
After receiving this error, the layers from the DataStore are no longer available until I shut down & restart GeoServer.
I have not seen any evidence (yet) of an ArcSDE state being created by 1.6.4, but that's probably because I haven't been able to set up any FeatureTypes.
My testing on 1.6.4 has been on our non-production instance of ArcSDE. I have not yet been able to determine whether any differences in user permissions between our production & non-production instances may be contributing to this difference in results.
Any suggestions are greatly appreciated!
Mike Olkin
GIS Administrator, Town of Amherst
4 Boltwood Avenue, Amherst, MA 01002
PH | 413-259-3247 FX | 413-256-4006
http://gis.amherstma.gov
See Amherst in 3D: http://gis.amherstma.gov/3D
I can confirm the state locks with 1.6.3, we've run into those as well.
Best regards,
Bart
The following exception was thrown: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
Mike Olkin GIS Administrator, Town of Amherst 4 Boltwood Avenue, Amherst, MA 01002 PH | 413-259-3247 FX | 413-256-4006 http://gis.amherstma.gov See Amherst in 3D: http://gis.amherstma.gov/3D
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
Bart van den Eijnden
OSGIS, Open Source GIS
bartvde@anonymised.com
http://www.osgis.nl
Hi Bart and Michael,
I was just going to ask you to try out the latest nightly but before doing so
I wanted to try it myself and found the arcsde extension were not including
the needed geotools jar, so I went ahead and fixed the build configuration as
per <http://jira.codehaus.org/browse/GEOS-1953&gt;\.
That means you'll have to wait until tomorrow to pick tonight's nightly which
should include the needed jars.
That said, please test over a non production arcsde instance first, since
1.7.x is _alpha_. Yet the arcsde support should be really really better,
which doesn't mean there might not be outstanding issues still.
So if you could grab [1] and [2] tomorrow and try it out that would be of a
great help for us too. Note the GeoTools ArcSDE plugin has been reworked to
solve the threading and performance issues we were having, and so far it
seems to be a resounding success.
Gabriel
[1]<http://gridlock.openplans.org/geoserver/trunk/geoserver-trunk-latest-bin.zip&gt;
[2]<http://gridlock.openplans.org/geoserver/trunk/ext-latest/geoserver-1.7.0-SNAPSHOT-arcsde-plugin.zip&gt;
Best regards,
Bart
> FeatureTypes.
> Thanks,
> Mike Olkin
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
On Thursday 29 May 2008 01:57:08 pm Gabriel Roldán wrote:
On Thursday 29 May 2008 12:56:25 pm bartvde@anonymised.com wrote:
> Hi Gabriel,
> but the zip file only contains: commons-pool and jsqlparser, not the
> actual gt2-arcsde jar?
yes, that's the build script problem I fixed yesterday and why I asked to
wait for last night build, but now I found the nightly were not built. In
another message to the list I asked Justin to look at the build logs to see
why the nightly was not built.
Okay, the nigthly is build now, so feel free to try it out at your
convenience.
Gabriel
Hello Gabriel,
i have exactly the same problem with Geoserver 1.6.4 (unstable datastore
connection to ArcSDE) as described by Michael.
I tested the "geoserver-1.7.0-SNAPSHOT-arcsde-plugin.zip" with Geoserver
1.7.0 as proposed by you [2].
The connection to ArcSDE is now stable. When i create a new feature type
from an existing ArcSDE datastore connection i get the following message in
the Geoserver Admin GUI:
java.lang.NoClassDefFoundError: org/geotools/data/QueryCapabilities
The Geoserver Logfile says:
2008-06-02 16:28:00,901 ERROR [[/geoserver170].[action]] - Servlet.service()
for servlet action threw exception
  at
org.geotools.arcsde.data.ArcSDEDataStore.getFeatureSource(ArcSDEDataStore.java:337)
  at
org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:132)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
  at
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at
  at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at
  at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
  at
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
  at
  at
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at
  at
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at
org.apache.catalina.valves.FastCommonAccessLogValve.invoke(FastCommonAccessLogValve.java:482)
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
  at
org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
  at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
  at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
  at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
  at java.lang.Thread.run(Unknown Source)
I made the test with Oracle 9i Rel. 9.2.0.8 and ArcSDE 9.1 with the
corresponding jpe91_sdk.jar and jsde91_sdk.jar.
Any help is appreciated,
Cornelius
so
including
as
which
a
to
Gabriel
Best regards,
Bart
a
of
DataStore
nicely.
that
reconciling
-1
> FeatureTypes.
I
> Thanks,
> Mike Olkin
View this message in context: http://www.nabble.com/Odd-behavior-with-ArcSDE-DataStore-tp17495983p17603494.html
hmm..
the exception clearly says that class is not in your classpath, which
shouldn't happen with the right combination of geoserver and arcsde extension
snapshots.
Did you also download the geosrever binary among the sde extension? or tried
the sde extension with a previous 1.7.x geoserver snapshot?
cheers,
Gabriel
On Monday 02 June 2008 05:04:50 pm Cornelius Schweizer wrote:
Hello Gabriel,
Servlet.service() for servlet action threw exception
  at
ava:337) at
eTypesNewAction.java:132) at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101) at
ssor.java:431) at
) at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432) at
  at
nFilterChain.java:269) at
hain.java:188) at
EncodingFilter.java:108) at
nFilterChain.java:215) at
hain.java:188) at
hainProxy.java:264) at
rityInterceptor.java:107) at
curityInterceptor.java:72) at
hainProxy.java:274) at
onFilter.java:110) at
onymousProcessingFilter.java:125) at
rMeProcessingFilter.java:142) at
SecurityContextHolderAwareRequestFilter.java:81) at
lter.java:217) at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106) at
SessionContextIntegrationFilter.java:229) at
  at
) at
hain.java:188) at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69) at
hain.java:188) at
  at
hain.java:188) at
ava:210) at
ava:174) at
7) at
7) at
LogValve.java:482) at
a:108) at
  at
  at
Connection(Http11BaseProtocol.java:665) at
va:528) at
orkerThread.java:81) at
va:685) at java.lang.Thread.run(Unknown Source)
Cornelius
> doing so
> including
> configuration as
> which
> a
> to
> Cheers,
> Gabriel
>bin.zip>
>7.0-SNAPSHOT-arcsde-plugin.zip>
>> Best regards,
>> Bart
>> > running
>> a
>> of
>> DataStore
>> nicely.
>> that
>> reconciling
>> > error: GeoServer - Exception
>> -1
>> > FeatureTypes.
>> I
>> > Thanks,
>> > Mike Olkin
>> > _______________________________________________
I did not download and use the geoserver binary. I only used the sde
extension with a previous (the latest 1.7.0) geoserver snapshot. Ok, then
this is my problem.
Because i use geoserver with Apache Tomcat as .war; is it possible to
provide the latest geoserver as a .war file (instead of bin) ?
Then i could test this problem again. Thanks.
hmm..
extension
snapshots.
tried
cheers,
Gabriel
Hello Gabriel,
in
  at
ava:337) at
ssor.java:431) at
) at
at
  at
hain.java:188) at
hain.java:188) at
lter.java:217) at
at
  at
) at
hain.java:188) at
hain.java:188) at
  at
hain.java:188) at
ava:210) at
ava:174) at
7) at
7) at
a:108) at
  at
  at
va:528) at
Cornelius
> doing so
> including
> configuration as
> which
since
better,
of
> a
reworked
> to
it
> Cheers,
> Gabriel
>bin.zip>
well.
>> Best regards,
>> Bart
>> > running
>> a
time
use
>> of
of
>> DataStore
>> nicely.
>> that
it
create
>> reconciling
state,
edits.
DataStore.
range:
>> -1
by
>> > FeatureTypes.
ArcSDE.
>> I
>> > Thanks,
>> > Mike Olkin
View this message in context: http://www.nabble.com/Odd-behavior-with-ArcSDE-DataStore-tp17495983p17618022.html
indeed:
<http://gridlock.openplans.org/geoserver/trunk/geoserver-trunk-latest-war.zip&gt;
let me know how it goes.
Gabriel
this is my problem.
> hmm..
> extension
> snapshots.
> tried
> cheers,
> Gabriel
>> Hello Gabriel,
>> in
>> at
>>e.j ava:337) at
>>tur eTypesNewAction.java:132) at
>>oce ssor.java:431) at
>>236 ) at
>> at
>> at
>>tio nFilterChain.java:269) at
>>erC hain.java:188) at
>>ter EncodingFilter.java:108) at
>>tio nFilterChain.java:215) at
>>erC hainProxy.java:264) at
>>ecu rityInterceptor.java:107) at
>>rSe curityInterceptor.java:72) at
>>erC hainProxy.java:274) at
>>ati onFilter.java:110) at
>>(An onymousProcessingFilter.java:125) at
>>mbe rMeProcessingFilter.java:142) at
>>er( SecurityContextHolderAwareRequestFilter.java:81) at
>>gFi lter.java:217) at
>> at
>>ttp SessionContextIntegrationFilter.java:229) at
>>48) at
>>:98 ) at
>> at
>>e.j ava:210) at
>>e.j ava:174) at
>>:12 7) at
>>:11 7) at
>>ess LogValve.java:482) at
>>jav a:108) at
>>51) at
>>0) at
>>ess Connection(Http11BaseProtocol.java:665) at
>>.ja va:528) at
>>erW orkerThread.java:81) at
>>.ja va:685) at java.lang.Thread.run(Unknown Source)
>> Cheers,
>> Cornelius
>> > doing so
>> > including
>> > configuration as
>> > nightly which
>> since
>> better,
>> of
>> > a
>> reworked
>> > to
>> it
>> > Cheers,
>> > Gabriel
>> >bin.zip>
>> well.
>> >> Best regards,
>> >> Bart
>> >> > running
>> >> a
>> time
>> use
>> >> of
>> of
>> >> DataStore
>> >> nicely.
>> >> that
>> it
>> create
>> >> reconciling
>> state,
>> edits.
>> DataStore.
>> range:
>> >> -1
>> by
>> >> > any FeatureTypes.
>> ArcSDE.
>> >> I
>> >> > Thanks,
>> >> > Mike Olkin
Now it works fine, thanks.
ArcSDE datastores are now stable, i was able to create new featuretypes,
visualize them and query (feature info) in the internal openlayers preview
client.
Are you going to fix this problem also for Geoserver Version 1.6.4 stable or
just continue development/bug fixing on the newest 1.7.0 version ?
Best Regards,
Cornelius
indeed:
Gabriel
this is my problem.
> hmm..
> extension
> snapshots.
> tried
> cheers,
> Gabriel
>> Hello Gabriel,
datastore
Geoserver
type
message
>> in
>> at
>>e.j ava:337) at
at
>>236 ) at
>> at
>> at
>> at
>> at
>>48) at
>>:98 ) at
>> at
>>e.j ava:210) at
>>e.j ava:174) at
>>:12 7) at
>>:11 7) at
>>jav a:108) at
>>51) at
>>0) at
>>.ja va:528) at
>> Cheers,
>> Cornelius
>> > doing so
>> > including
>> > configuration as
>> > nightly which
>> since
>> better,
be
>> of
>> > a
>> reworked
>> > to
far
>> it
>> > Cheers,
>> > Gabriel
>> >bin.zip>
>> well.
>> >> Best regards,
>> >> Bart
>> >> > running
>> >> a
>> time
read-only
>> use
>> >> of
releases
>> of
>> >> DataStore
>> >> nicely.
was
>> >> that
started,
>> it
>> create
>> >> reconciling
>> state,
>> edits.
>> DataStore.
>> range:
>> >> -1
created
>> by
>> >> > any FeatureTypes.
>> ArcSDE.
>> >> I
user
>> >> > Thanks,
>> >> > Mike Olkin
View this message in context: http://www.nabble.com/Odd-behavior-with-ArcSDE-DataStore-tp17495983p17646272.html
