[Geoserver-users] Odd behaviour with WFS GetFeature in Geoserver 2.7.1.1 - property names (and geometry) returned that are not requested.
If I make this POST query to our server:
http://maps.gns.cri.nz/geoserverlatest (public)
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs&quot; service="WFS" version="1.1.0" count="1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs/xsd&quot; outputFormat="application/json"><wfs:Query typeName="gns:PETROLEUM.PETROLEUM_BOREHOLE_VIEW" srsName="EPSG:4326"><wfs:PropertyName>BH_NAME</wfs:PropertyName><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;&lt;ogc:Intersects&gt;&lt;ogc:PropertyName&gt;SHAPE&lt;/ogc:PropertyName&gt;&lt;gml:Polygon xmlns:gml="http://www.opengis.net/gml&quot; srsName="EPSG:4326"><gml:exterior><gml:LinearRing><gml:posList>170.0244140625 -44.8714427501659 170.0244140625 -44.68427737181224 169.7607421875 -44.68427737181224 169.7607421875 -44.8714427501659 170.0244140625 -44.8714427501659</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></ogc:Intersects></ogc:Filter></wfs:Query></wfs:GetFeature>
Then I get three properties returned, BH_NAME, BH_ID, and BH_TYPE_ID (there are a large no. of other properties that could be returned and are if you remove the <wfs:PropertyName>BH_NAME</wfs:PropertyName> from the query).
I expect only BH_NAME.
Worse, (far worse), it returns the geometry despite not having SHAPE in the property lsit. For the above feature type, this doesnt matter but if I make WFS queries on a complex polygon classes to fetch attributes only from a spatial search, then I get swamped by multi-megabytes of geometry in the response.
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St, Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Phil,
your schema makes BH_ID, SHAPE, and BH_TYPE_ID mandatory (minOccurs=1 and nillable=false):
http://maps.gns.cri.nz/geoserverlatest/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=gns%3APETROLEUM.PETROLEUM_BOREHOLE_VIEW
I far as I know, JDBC feature sources make a property mandatory by default if the underlying database column has a NOT NULL constraint. You may be able to change this with GeoServer schema mapping:
http://docs.geoserver.org/stable/en/user/services/wfs/schemamapping.html
The GeoJSON spec requires a geometry property but permits it to be null; I do not know whether GeoServer JSON outputFormat encodes a geometry if the geometry property is not mandatory and not requested.
Kind regards,
Ben.
the query).
in the response.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
That is very interesting. Thanks for that.
thanks for that. However, I get geometry even if outputformat is GML or CSV. This didnt happen in earlier geoserver versions.
What happens if you use schema mapping to make the geometry optional?
The code that looks like it makes a NOT NULL property mandatory seems to have been around for at least five years, but it is possible that WFS is now better at honouring it.
Kind regards,
Director
New Zealand
On Fri, Jan 15, 2016 at 1:48 AM, Phil Scadden <p.scadden@anonymised.com> wrote:
I'd be very surprised if that was the case, the engine deciding whether to
include
a property or not in the output does not know which output format is being
used,
it never did as far as I know.
The store level recognition of constraints did not change recently either
(that I know at least)...
how old was the GeoServer you're trying to replace?
Could it be that the table constraints changed around the same time you
upgraded GeoServer instead?
Or have you maybe switched from SDE to direct Oracle spatial usage
(different
store, different behavior).
Thinking out loud, we could have a flag at the store level to make all
properties
nullable even if they are not... and then disallow editing on those same
tables
(since it cannot be done anymore in a predictable fashion, DFT says you can
skip an attribute, but then you cannot).... or just document that at that
point WFS-T
is not going to work reliably.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Misunderstanding. I am not asserting that properties returned depend on outFormat. Ben seemed to be suggesting this might be why I am getting geometry. What I am asserting is that earlier version didnt return geometry if it wasnt on the property list.
No. SHAPE is nullable in the underlying SDE store. The maintenance process for the table regularly sets shape to null to force recalculation of the geometry from attributes in the same table. I assert that I am not getting the geometry because shape is set to not null.
I wish… No, still stuck with SDE.
The constraint of requiring not null properties to be returned regardless of whether in property list, is only useful within the context of WFS-T. That should be the flagging criteria. If not in a WFS-T context, then only send properties requested. I suspect that editing is rare but querying is common. I think OGC should consider a nogeometry switch like arcGIS server.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
I’d be very surprised if that was the case, the engine deciding whether to include
a property or not in the output does not know which output format is being used,
Or have you maybe switched from SDE to direct Oracle spatial usage (different
Thinking out loud, we could have a flag at the store level to make all properties
nullable even if they are not… and then disallow editing on those same tables
skip an attribute, but then you cannot)… or just document that at that point WFS-T
On Sun, Jan 17, 2016 at 1:19 PM, Phil Scadden <p.scadden@anonymised.com> wrote:
properties
tables
point WFS-T
I agree with you, OGC did not give us a DescribeFeatureType for WFS-T and
one for basic.
DescribeFeatureType generates a XML schema that we have to abide to, at
least for GML outputs (otherwise they would be schema invalid).
Given we have only one, if we make the attributes nullable in the schema
when they are not in the db, we'll be able to ask for the property
to be removed in GetFeature, but the data will not be properly editable. If
we make it editable, then you're also forced to get it in the output...
I agree for "nogeometry", but imho it should be more general, there might
be other fields that are mandatory in the db that you
don't care for in the output. Maybe a "ignoreNonNull=true" property in the
GetFeature request that would force it to just listen
to the properties being requested, instead of also double checking what's
mandatory in the schema (and maybe add the
same param in the DescribeFeatureType backlink that we generate, so that
the output also confirms nothing is mandatory).
Just thinking out loud :-p
Ing. Andrea Aime
@geowolf
Technical Lead
+1 for a nogeometry switch. We need some way to support GetFeatureInfo but not return geometry, for security reasons. Actually it would be great to support returning a BBOX rather than the actual geometry, since this supports zooming. This improves both security and performance.
