Hi list,
On my “Service capabilities” list provided on the GeoServer homepage, the top one is “GWC” which links to:
http://wppgeog3:8082/geoserver/ows?service=gwc&version=1.0.0&request=GetCapabilities
However when I click it I get:
ows:ExceptionText
No such operation gwc 1.0.0 GetCapabilities
</ows:ExceptionText>
Does anyone else have it, and does it work for them? What’s it supposed to do? I’m suspect it’s a bug, but figured it’s worth asking first.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Jonathan,
I have observed the same behaviour with the gwc capabilities, while the others capabilities (WMTS,WMS-C,TMS) work fine.
I tested this with a clean installation of geoserver 2.3.3 under Apache Tomcat 7.0.37 (ubuntu 12.04 LTS)
Michele
On Tue, Jul 9, 2013 at 6:32 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi list,
ows:ExceptionText
Jonathan
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Thanks Michele,
Jira issue opened - http://jira.codehaus.org/browse/GEOS-5886
Jonathan
Hi list,
ows:ExceptionText
Jonathan
