Hi Jody,
actually… the WFS 2.0 specification leaves out a possibility to return “unknown” in the count numberMatched field, from the schemas:
<xsd:attributeGroup name=“StandardResponseParameters”>
<xsd:attribute name=“timeStamp” type=“xsd:dateTime” use=“required”/>
<xsd:attribute name=“numberMatched” type=“wfs:nonNegativeIntegerOrUnknown” use=“required”/>
<xsd:attribute name=“numberReturned” type=“xsd:nonNegativeInteger” use=“required”/>
<xsd:attribute name=“next” type=“xsd:anyURI”/>
<xsd:attribute name=“previous” type=“xsd:anyURI”/>
</xsd:attributeGroup>
<xsd:simpleType name=“nonNegativeIntegerOrUnknown”>
xsd:union
xsd:simpleType
<xsd:restriction base=“xsd:string”>
<xsd:enumeration value=“unknown”/>
</xsd:restriction>
</xsd:simpleType>
xsd:simpleType
<xsd:restriction base=“xsd:nonNegativeInteger”/>
</xsd:simpleType>
</xsd:union>
</xsd:simpleType>
To use it, configure the layer to skip number matched (publishing/wfs):
I believe this setting is not used often though, not sure how many clients are ready to receive “unknown” rather than a number.
I also see that when setting it, the numberReturned is zero… and it should not be, but I don’t know why it’s happening.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Jody Garnett
