Hello Arturo!!
I don’t know if it’s going to fix your problem, but today I’ve had problems with displaying popups with openlayers, and there was another problem with a bbox draw…
Then, I just downloaded the last OpenLayers version (2.7) from
openlayers.org, descompressed the file (.tar.gz) and moved the OpenLayers-2.7 directory inside geoserver’s one…
In my code, I’ve referenced it like: http://localhost:8080/geoserver/OpenLayers-2.7/OpenLayers.js and it worked fine!!!
I’m using geoserver 1.6.5.…
Try to make this change and MAYBE it works…
(If you want to be sure that this can be a version problem, I suggest you to download an older version of OpenLayers and try it… and when I say older, I mean a release made before Firefox 3)
I hope to help…
Rodrigo
Rodrigo C. Antonialli
Rio Claro - SP - Brasil
LinkedIn: http://www.linkedin.com/in/rcaprofile
Contato: (19) 9757-0370
rca.cirdan@anonymised.com
rcantonialli@anonymised.com
Skype: rc_antonialli
On Tue, Nov 4, 2008 at 12:45, Arturo Juàrez <ajuarez@anonymised.com.> wrote:
this is my code, maybe my error is in are many together layers.
<html xmlns=“http://www.w3.org/1999/xhtml”>
#map {
width: 806px;
height: 560px;
border: 1px solid black;
#wrapper {
width: 836px;
#location {
float: right;
<link rel=“stylesheet” href=“http://172.16.23.21:8080/geoserver/openlayers/theme/default/style.css” type=“text/css” />
<script src=“http://172.16.23.21:8080/geoserver/openlayers/OpenLayers.js”>
WMS Example
Shows the basic use of openlayers using a WMS layer
Este es mi primer Demo!!
Arturo Juárez Lima
Andrea Aime escribió:
Arturo Juàrez ha scritto:
are there other tools besides of openlayers for publish the maps ?
OpenGeo uses OpenLayers exclusively, we had no such problems
as you so far. But yeah, there are others, such as the
Flamingo map components, or MapBender (just to cite the first
two that come to my mind).
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
