I just wanted to chime in here, as I happened to be looking into the same thing at the moment. I’m new to the list, so forgive me if this has been talked about already. What I’m trying to do, is set-up a web-interface whereby residents can add point data with attributes to a map. I’ve got a nicely functional installation of GeoServer running, and WFS-T is obviously the way forward, but I’m having trouble “seeing” the system architecture. So far, this is what I see:
*PostGIS DB
*Geoserver backend, serving data stored in PostGIS through the WFS-T specification
*Front end - This is where I’m at a loss.
The link you provided Chris (http://geo.openplans.org/tschaub/wfsv/feature-editor.html#) looks like exactly what I need (although I didn’t see any attribute editing function ality (yet, I suppose)). So, currently, if you were out to make a map of your favorite restaurants & wanted people to add to it & store the data in a DB backend (not shapefiles,as I’ve learned), what is the best way forward?
Best Regards,
Andrew Schroeder
-------- Original Message --------
Subject: Re: [Geoserver-users] Open Street Map and Geoserver
Date: Thu, September 27, 2007 4:22 pm
To: “Tom (JDi Solutions)” tom.dean@anonymised.com
Cc: Rahkonen Jukka Jukka.Rahkonen@anonymised.com,
geoserver-users@lists.sourceforge.netYou can download the planet dump from OSM, and there are scripts to
convert it in to postgis, though I know of none for oracle.GeoServer does not support GPX or OSM. I think someone is writing a GPX
datastore, and writing one for OSM wouldn’t be hard. But the problem
with those will be there’s no spatial index, so they won’t serve very
fast. I’d recommend converting to a database to serve it. You also
could convert to shapefile, they have scripts to do that I believe,
though that holds up less well for transactions.As for reprojection, once you get the data in to GeoServer then it can
reproject it in to whatever projection you want.The one thing I’m not clear on is how you’d contribute back to OSM? If
you just use their editing interface then it works, but then it’d be
awhile till your data got the update. I would like to work with them to
figure out how we could set up GeoServer’s as nodes on to the main OSM
database, to let contributions there go back in. Soon we should be able
to handle logins, and perhaps could have a version that hooks straight
up to their user database and does authentication the same way, and then
could do batch imports to their main db.As for GeoCollaboration stuff, yeah, it’s goal is to enable similar
things in GeoServer, not so much direct integration, though it should
make direct integration easier, and we would be very psyched if OSM or
at least part of the community made use of GeoServer. They’ve shown no
interest in the past, but we lacked authors and versions and all, which
are now emerging.We still need to do a lot of UI work on it, but you can see our first
sketches at http://geo.openplans.org/tschaub/wfsv/feature-editor.html#
It’s better when you set most of the preferences to true. And you can
try viewing the history and do diffs there, and then click on numbers to
do rollbacks.Chris
Tom (JDi Solutions) wrote:
Thanks Jukka, I’ll check that out…
On 9/27/07, Rahkonen Jukka <Jukka.Rahkonen@mmmtike.fi
mailto:[Jukka.Rahkonen@mmmtike.fi](http://email.secureserver.net/pcompose.php#Compose)> wrote:Hi,
I have never tried it myself, but you can download all OSM data in
one bundle. Have a look at
http://wiki.openstreetmap.org/index.php/Planet.osm
<http://wiki.openstreetmap.org/index.php/Planet.osm>
If you are in UK there seems to be also a smaller excerp available.
From the same page you can find more advice as well. Tell if you
will have success.-Jukka Rahkonen-
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net
mailto:[geoserver-users-bounces@lists.sourceforge.net](http://email.secureserver.net/pcompose.php#Compose)
[mailto:geoserver-users-bounces@lists.sourceforge.net
mailto:[geoserver-users-bounces@lists.sourceforge.net](http://email.secureserver.net/pcompose.php#Compose)]
*Puolesta *Tom (JDi Solutions)
Lähetetty: 27. syyskuuta 2007 10:54
Vastaanottaja: geoserver-users@lists.sourceforge.net
mailto:[geoserver-users@lists.sourceforge.net](http://email.secureserver.net/pcompose.php#Compose)
Aihe: [Geoserver-users] Open Street Map and GeoserverHi all,
I wonder if someone has any experience of using Open Street
Map? I’d like to contribute to and then use Open Street Map
data in my applications but I have come up against several
problems and I wonder if anyone has any suggestions.
Open Street Map is recorded in lat/long (4326) but we use
British National Grid Projection (27700) so if I’m to be able to
display OSM data in OpenLayers I need to be able to convert the
bounding box for a WMS request to lat/long before requesting
it. Even then if my understanding of projections is correct it
will come out slightly skewed? I could use Oracle to do this
since it has a transform function which transforms co-ordinates
from one projection to another but this has been shown to have a
slight offset (with Google earth at least) so may not be good
enough. Does Geoserver have any external functions which can be
used without having to get into the java?Ideally it would be nice to be able to periodically copy the
data from Open Street Map, reproject the whole lot and then
serve it from our own server using Geoserver but Open Street Map
only allows downloads of small sets of data at a time and they
are in .GPX or .OSM and I can’t seem to find any way to convert
them. Does Geoserver have any plans to support either of these
formats?I have read the GeoCollaboration page on the wiki but this seems
to be less about direct integration with Open Street Map and
more about enabling that sort of project to be run using
Geoserver. Is that right?I realise I should probably post this to the Open Street Map
mailing list but I thought I’d get your thoughts on it first?Tom
!DSPAM:4005,46fb675092881030819293!
Defy all challenges. Microsoft(R) Visual Studio 2005.
http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/!DSPAM:4005,46fb675092881030819293!
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4005,46fb675092881030819293!
