[Geoserver-users] OpenStreetMap
Hi everybody,
I am new to GeoServer. It looks very good, but I have a question:
I have installed the PostgreSQL server with PostGIS. Then I created a database and putted the osm data with the osm2psql-tool.
What is the next step to render the data with GeoServer?
Thank you!
Heribert,
see: http://geoserver.org/display/GEOSDOC/PostGIS+DataStore
or in a few words - setup a new datastore, connect Geoserver to your database, then define a new feature type to one table in your database - then you have a basic WMS/WFS serving the data as service - basically this lets you show the data in a rough shape - the work to render the objects in the way you want to begins ... :wink:
Regards, Till
Hi everybody,
Thank you!
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams@anonymised.com http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
I have created a new DataStore sucessfully. But i don’t understand creating a new FeatureType. The Name of the new FeatureType seems to be read-only, there is only a drop-down-box. The new DataStore isn’t listed in the FeatureType-environment.
2009/1/7 Till Adams <adams@anonymised.com>
Heribert,
objects in the way you want to begins … :wink:
Regards, Till
Hi everybody,
Thank you!
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
Hi Heribert,
Yes, feature type names are read only. However when configuring a new feature type you have the ability to alias, ie provide an alternative name.
To configure a new feature type navigate to:
http://localhost:8080/geoserver/config/data/typeNew.do
Select the type you want from the drop down and click the New button. That will bring you to the configuration screen. Once you set up the metadata Submit, Apply, and then Save.
Hope that helps.
-Justin
Heribert Hansen wrote:
I have created a new DataStore sucessfully. But i don't understand creating a new FeatureType. The Name of the new FeatureType seems to be read-only, there is only a drop-down-box. The new DataStore isn't listed in the FeatureType-environment.
2009/1/7 Till Adams <adams@anonymised.com <mailto:adams@anonymised.com>>
    Heribert,
    Regards, Till
     > Hi everybody,
     > I am new to GeoServer. It looks very good, but I have a question:
     > I have installed the PostgreSQL server with PostGIS. Then I created a
     > database and putted the osm data with the osm2psql-tool.
     > What is the next step to render the data with GeoServer?
     > Thank you!
     > Check out the new SourceForge.net Marketplace.
     > It is the best place to buy or sell services for
     > just about anything Open Source.
     > http://p.sf.net/sfu/Xq1LFB
     > Geoserver-users mailing list
     > Geoserver-users@lists.sourceforge.net
    <mailto:Geoserver-users@lists.sourceforge.net>
     > https://lists.sourceforge.net/lists/listinfo/geoserver-users
    53111 Bonn
    Germany
    Till Adams
    Geschäftsführung
    Komplementärin:
    vertreten durch:
Justin Deoliveira
OpenGeo - http://opengeo.org
