Hi again,
here the log output relate to the query:
2013-11-21 10:01:07,906 DEBUG [org.geotools.jdbc] - SELECT count(*) AS gt_result_ FROM (SELECT * FROM “public”.“pozzi_decodificati_vigor” WHERE (“the_geom” && ST_GeomFromText(‘POLYGON ((18.71948828125 40.28446472745902, 19.074246093750002 40.28446472745902, 19.074246093750002 39.92970692827869, 18.71948828125 39.92970692827869, 18.71948828125 40.28446472745902))’, 0) AND ST_Intersects(“the_geom”, ST_GeomFromText(‘POLYGON ((18.71948828125 40.28446472745902, 19.074246093750002 40.28446472745902, 19.074246093750002 39.92970692827869, 18.71948828125 39.92970692827869, 18.71948828125 40.28446472745902))’, 0)) AND (‘ALL_LABEL_CLASSES_ENABLED’ = ‘ALL_LABEL_CLASSES_ENABLED’ AND 1 = 1)) LIMIT 50) gt_limited_
2013-11-21 10:01:07,925 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2013-11-21 10:01:07,925 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Internal error occurred
at org.geoserver.wms.GetFeatureInfo.execute(GetFeatureInfo.java:177)
at org.geoserver.wms.GetFeatureInfo.run(GetFeatureInfo.java:122)
at org.geoserver.wms.DefaultWebMapService.getFeatureInfo(DefaultWebMapService.java:371)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy28.getFeatureInfo(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.RuntimeException: java.io.IOException
at org.geotools.data.store.ContentFeatureCollection.size(ContentFeatureCollection.java:354)
at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.size(ForceCoordinateSystemFeatureResults.java:105)
at org.geoserver.wms.GetFeatureInfo.execute(GetFeatureInfo.java:278)
at org.geoserver.wms.GetFeatureInfo.execute(GetFeatureInfo.java:173)
… 84 more
Caused by: java.io.IOException
at org.geotools.jdbc.JDBCDataStore.getAggregateValue(JDBCDataStore.java:1289)
at org.geotools.jdbc.JDBCDataStore.getCount(JDBCDataStore.java:1219)
at org.geotools.jdbc.JDBCFeatureSource.getCountInternal(JDBCFeatureSource.java:409)
at org.geotools.data.store.ContentFeatureSource.getCount(ContentFeatureSource.java:413)
at org.geotools.data.store.ContentFeatureCollection.size(ContentFeatureCollection.java:327)
… 87 more
Caused by: org.postgresql.util.PSQLException: ERROR: Operation on mixed SRID geometries
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:252)
at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at org.geotools.jdbc.JDBCDataStore.getAggregateValue(JDBCDataStore.java:1269)
… 91 more
I tried also to delete the layer and re-publish it.
I checked the srid with:
select distinct(SRID(the_geom)) as srid, count(*) from pozzi_decodificati_vigor group by srid
and I get only one record: 4326
of course an upgrade could be a good and quick solution, but also understand why it happens is curios!
regards
Eugenio
Date: Thu, 21 Nov 2013 09:48:42 +0100
Subject: Re: Operation on mixed SRID geometries
To: frippe12573@anonymised.com
CC: geoserver-users@lists.sourceforge.net
On Thu, Nov 21, 2013 at 9:46 AM, Eugenio Trumpy <frippe12573@anonymised.com> wrote:
yes I modify the query for producing that view (excluding the rows without coordinates),
but still doesn’t work.
In the preview I see the features but no info on items, with that error.
Enable “geotools developer logging” and hunt in the logs the query being used.
Make sure you don’t have “prepared statements” enabled.
What query is being used?
