Ok, so this GeoServer still thinks the srid is 0.
The srid is read the first time GeoServer tries to access that view
(normally, during startup when checking if the feature type can be computed)
and from there on, it won’t consult the geometry_columns anymore.
Well, unless you force it to, by using the “reset” button in the status
page, or by restarting GeoServer fully
I ‘reset’ geoserver and also restart, but it still read the query in the wrong way.
Any other suggestions?
Regards
Eugenio
On Thu, Nov 21, 2013 at 10:41 AM, Eugenio Trumpy <frippe12573@anonymised.com>wrote:
So the upgrade is the most quick solution,
I can do it, but have you any hints since I have to change from 2.1.2 to
the stable 2.4...?
Make a backup of your data directory, there has been reports of issues
during the upgrades related
to the security subsystem upgrade
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
actually the result of that query has srid value = 0
E.
Date: Thu, 21 Nov 2013 10:43:04 +0100
Subject: Re: FW: Operation on mixed SRID geometries
To: frippe12573@anonymised.com
CC: andrea.aime@anonymised.com
2013/11/21 Eugenio Trumpy <frippe12573@anonymised.com>
Regards
Eugenio
Did you try, as suggested by Andrea, to check what SRID is registered in geometry_columns Postgis metadata view?
select * from public.geometry_columns where f_table_name = ‘<your_view>’;
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Eugenio,
your issue seems very similar to this one:
https://jira.codehaus.org/browse/GEOS-4937
it indeed affected 2.1.3 release but it was fixed in 2.1.4
Stefano
41.95581N 12.52854E
2013/11/21 Stefano Iacovella <stefano.iacovella@anonymised.com>
Regards
Eugenio
Stefano
41.95581N 12.52854E
So GeoServer can't recognize native SRS.
By the way, which version of PostGIS are you using?
Stefano
41.95581N 12.52854E
2.0.3 r11128
Date: Thu, 21 Nov 2013 10:55:55 +0100
Subject: Re: Operation on mixed SRID geometries
CC: andrea.aime@anonymised.com; geoserver-users@anonymised.comourceforge.net
2013/11/21 Eugenio Trumpy <frippe12573@anonymised.com5…>
So GeoServer can’t recognize native SRS.
Stefano
41.95581N 12.52854E
Do you loaded the data contained in the table used from the view with the shp2pgsql utility?
If so it does not use the typmod feature for adding the geometry column to the table, when creating views PostGIS does not populate the geometry_columns unless you perform a cast on the geoemtry column of the view.
You may try dropping your view and recreating using a syntax like this:
create view xxx as
select
the_geom::geometry(POLYGON,4326) As the_geom
from
Of course change the POLYGON according to your shape type
Stefano
41.95581N 12.52854E
2.0.3 r11128
CC: andrea.aime@anonymised.com…; geoserver-users@lists.sourceforge.net
Stefano
41.95581N 12.52854E
