[Geoserver-users] Oracle connection
Hi folks,
I am setting up a WFS-server using Geoserver 1.5.0. I added a new datastore
(an oracle spatial database) and everything went fine, but now when setting
the featuretype section when I pressed the "generate" button to
automatically fill in the lat/lon, I got the following error: "The
FeatureType 'Name of the table' has a NULL extent. HINT: the dataset is
empty or has no default geometry attribute." However my Featuretype has not
a NULL-extent.
I read on the forum that someone solved this problem creating a primary key
for the table, Does anyone know any other way to solve it??
Thanks for your help, much appreciated,
Best regards,
Juan Arévalo.
View this message in context: http://www.nabble.com/Oracle-connection-tf3865826.html#a10951648
Juan Arévalo ha scritto:
Hi folks,
a NULL-extent.
None. The oracle datastore won't function properly if you don't have a primary key in the tables.
