Am a little bit in a bind. I have loaded the shape files in an SQL database
and am able to make in work with Geoserver with no issues under Layer
Preview. The problem arises when I have loaded the exact same shape files
into an Oracle database. Nothing seems to load and it comes up with a
rendering time out message. I increased the time frame to 90s, 120s and
240s and nothing seems to work. Do note that with the same default
settings, everything load OK with an SQL Server database.
Any input or direction is greatly appreciated!
Using Geoserver 2.0.3, SQL Server 2008 and Oracle 11gR2
sounds odd, very odd. I guess you have the gt-jdbc-oraclexxx.jar and the
ojdbc14.jar in the lib directories. I further assume the tables are
indexed, including a spatial index and analysed.
I would do two things first before doing anything with Geoserver. Download
QGis and try to display it with QGis or use SQL developer and try to do a
spatial query on the dataset. Only after assuring that the tables are o.k. I
would look into Geoserver.
And you are sure there is nothing in the log files, the datastore is o.k.
and the preview works o.k., i.e. displays all controls but a white canvas?
What happens with a direct WMS request?
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department Environment and Primary Industries
Level13, Marland House, 570 Bourke Street
Melbourne 3000
I have figured out the problem. It had to do with the creation of an entry
in the ORACLE USER_SDO_GEOM_METADATA table in order to create the Spatial
index.
I originally set it to the ff (copied this off the web as I was not able to
create spatial indexes without it):
On Tue, Nov 19, 2013 at 2:09 PM, rkliao <rkliao@anonymised.com>wrote:
Thanks for the reply.
index.
Unquoted Oracle identifiers are converted to uppercase; this may be significant in USER_SDO_GEOM_METADATA values, as lowercase string values (table and column names) will not match.
Kind regards,
Ben.
index.
Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now. http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
I had to do this again with another set of shapes and is ending up with
Geoserver timing out even if I had created the indexes. Is there something
else I might be missing?
