Does anyone know where to find Oracle_Data_ref_set.sql for gs-app-schema-test? It is no included in the source download.
Wen
Wen
Wen,
Oracle_Data_ref_set.sql can found in refdataset-1.0-1.0.7.jar, which you can get from your local maven repository or the osgeo maven repository:
http://download.osgeo.org/webdav/geotools/org/geotools/data/refdataset-1.0/1.0.7/refdataset-1.0-1.0.7.jar
In March I wrote: "as far as I know, the data reference set exists only as a jar file. The management workflow is to obtain the jar, unzip it, edit the enclosed SQL, re-zip it, increment the version number, and manually deploy it to the osgeo maven repository."
http://sourceforge.net/p/geotools/mailman/message/33529509/
There is some more information on the these tests here:
https://www.seegrid.csiro.au/wiki/Infosrvices/DataReferenceSet
https://www.seegrid.csiro.au/wiki/Infosrvices/JenkinsGeoserverMasterTechnicalNotes
https://osgeo-org.atlassian.net/browse/GEOS-6883
Kind regards,
Ben.
On 29/09/15 01:51, Yin, Wentao (IS) (Contr) wrote:
Wen------------------------------------------------------------------------------
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Got it. Thank you, Ben.
Wen
-----Original Message-----
Sent: Monday, September 28, 2015 4:28 PM
To: Yin, Wentao (IS) (Contr); geoserver-users@lists.sourceforge.net
Subject: EXT :Re: [Geoserver-users] Oracle_Data_ref_set.sql
Wen,
Kind regards,
Ben.
--------_______________________________________________
Ben Caradoc-Davies <ben@...6881...>
Director
Transient Software Limited <http://transient.nz/> New Zealand
There is also a page in the developer manual:
App-Schema Online Tests
http://docs.geoserver.org/latest/en/developer/programming-guide/app-schema/index.html
Director
New Zealand
Thanks, Ben
Wen
Sent: Monday, September 28, 2015 5:22 PM
chnicalNotes
Director
