There are two pull requests improving Oracle database driver support that are caught in a catch-22. The problem is that none of the regular developers have access to an Oracle instance so these cannot be merged.
This is a request for feedback on either or both of these pull requests so that they are validated and can be merged and make using Oracle databases easier in future releases of GeoTools and GeoServer.
Hi!
I do believe that Oracle has a free XE edition, and also is free to use for development.
Hälsning / Regards
Mats.E
Skickat från min / Sent from my iPhone, Ursäkta att jag är kortfattad / Excuse my brevity.
15 apr. 2020 kl. 10:13 skrev mark <mc.prins@anonymised.com>:
the issue is indeed not money but finding time to set it up and run the tests.
I had a Oracle 12 docker image locally, but it was using lots of space that I needed to work with OSM data, and had to wipe it out…
I set it up a handful of times by now, always a pain, takes time, searches over the internet for strange commands, fighting with permissions and the like… typically eats away 2-4 hours for me (but to be honest, I use Oracle maybe 1-2 days a year, so it just keeps on being unfamiliar). Believe other core devs are in the same boat, if they are not so blessed as to never touch Oracle DB at all :-p
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea et al!
Lack of access to certain environments seem to be a returning problem in FOSS development. However, the need for those environments indicate the the user community uses them.
Provided that licensing does not interfere, I would suggest that a cloud service be established, in this case for example with an Oracle instance and suitable set of geodata loaded.
This cloud computer could be very slim in terms of cores and RAM since it would do only limited work. If it was normally shut down, and only booted when needed, the monthly cost could be kept at a minimum.
The computer and software would of course need to be maintained, but I am sure this knowledge exists in the user community.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Hi Olle,
thanks for looking into it. It’s a empty schema with full rights within it, the tests are creating and destroying tables
into it multiple times per test.
I will post a quick note on how to set up the Oracle schema, at least for 12.2, tomorrow when I get back in the office.
I currently have this module set up on our in-house Jenkins.
Hi Olle,
For environments requiring setup (MongoDB, Oracle, Elasticsearch) the is really a team effort where we rely on our community to test release candidates, and in this case review a pull request.
In this specific case, if we had a volunteer to setup an online test (using Oracle XE) we would be able to provide faster / better service with lower effort. The test provides its own data and is setup with this environment in mind.
As Andrea indicated we lack a passionate module maintainer for Oracle, if you two have knowledge on this is a great opportunity to take part.
Passionate being the keyword, as in, someone that would use their spare time. Oracle is covered, but only during working hours, under contract.
The issue we’re having here is that a review is needed, which implies among other things running tests, but there is no contract covering it and
allowing usage of work hours, leaving it to the good will of those that would use their spare time to setup Oracle, run the tests, review the changes.
something along the following should do for creating an integration test schema for Geotools (your DBA may disagree with this, it’s what they do, especially when it comes to Oracle DBA’s):
– create user GEOTOOLS with password “geotools” using defined tablespaces
CREATE USER “GEOTOOLS” IDENTIFIED BY “geotools”
DEFAULT TABLESPACE “DATA_TS”
TEMPORARY TABLESPACE “TEMP”
– grant roles
GRANT “CONNECT” TO “GEOTOOLS”
GRANT “RESOURCE” TO “GEOTOOLS”
– system grants
GRANT CREATE SESSION TO “GEOTOOLS”
GRANT ALTER SESSION TO “GEOTOOLS”
GRANT UNLIMITED TABLESPACE TO “GEOTOOLS”
GRANT CREATE TABLE TO “GEOTOOLS”
GRANT CREATE SYNONYM TO “GEOTOOLS”
GRANT CREATE VIEW TO “GEOTOOLS”
GRANT CREATE SEQUENCE TO “GEOTOOLS”
GRANT CREATE PROCEDURE TO “GEOTOOLS”
GRANT CREATE TRIGGER TO “GEOTOOLS”
GRANT CREATE MATERIALIZED VIEW TO “GEOTOOLS”
GRANT CREATE OPERATOR TO “GEOTOOLS”
And then in your ~/.geotools a file called “oracle.properties” with the following content:
You’ll need to change the IPadress and database instance in there ofcourse
running the test locally can be accompished using:
mvn clean install -Dall -pl :gt-jdbc-oracle -Ponline -Doracle=true (for master branch)
and
mvn clean install -Dall -pl :gt-jdbc-oracle -Ponline (for feature branch, as the oracle property was removed)
Disclaimer;
This message is just a reflection of what I thought at the time of sending. The message may contain information that is not intended for you or that you don’t understand.
Hi Mark,
thanks for the update… maybe that should be in a README for the module, indicated as a suggestion.
Thinking out loud about our current predicament… one way to solve it, would be to add a gihub action running
a oracle VM, and running the tests, similar to the one I recently added for PostGIS:
If something like this could be setup, it would solve all future issues regarding running Oracle tests for PRs.
