[Geoserver-users] Oracle Georaster and IMAGEmosaic JDBC
Hi All,
Currently I am working on connecting geoserver to the Oracle GeoRaster. From
the user manual, I figure out that IMAGEmosaic JDBC is the way to go.
However, I just need to confirm my understanding of this extension is
correct:
1. in order to use it, you have to setup the data layout identified in the
tutorial, which means it doesn't support the GEORASTER oracle format, right?
The image just stored in oracle as dump data (binary data) rather than
GEORASTER data format.
correct me if I am wrong, thank u guys in advance!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Oracle-Georaster-and-IMAGEmosaic-JDBC-tp5052430.html
This thread may of use to you:
http://osgeo-org.1560.x6.nabble.com/ImageMosaic-JDBC-setup-for-Oracle-GeoRaster-How-td3794491.html
Jonathan
On 9 May 2013 21:44, dywdaniel <yunwei.dong@anonymised.com> wrote:
Hi All,
correct:
    tutorial, which means it doesn’t support the GEORASTER oracle format, right?
Introducing AppDynamics Lite, a free troubleshooting tool for Java/.NET
Get 100% visibility into your production application - at no cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap1
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Daniel,
If you keep this on-list then people who actually know about it might see it. I don’t know the first thing about Oracle GeoRaster or JDBC. :slight_smile:
My own guess would be maybe you need quote marks around your username and password:
On Sat, Jun 8, 2013 at 9:00 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Jonathan
Hi All,
correct:
Yunwei(Daniel) Dong
PhD candidate,
Specialization in Geomatics
Geography, Faculty of Environment
University of Waterloo
200 University Ave W,
Waterloo, ON, CA
N2L 2G1
Tel: (+1) 519-729-6626
