Hello
I am trying to use geoserver with oracle. I have installed the datastore and
I can creste festuretypes without any problem, but when I try to see the map
in the demo I only get a blank map. The bbox is the one generated by the
rpogram.
Can anyone help me?
Thank you
View this message in context: http://www.nabble.com/Oracle-%2B-Geoserver-%3D-Blank-tp18384829p18384829.html
An empty map usually indicates that your styles are not very well suited to
the request (ie, no rules to draw anything at the current zoomlevel). Please
try setting style=polygon (or point, or line, depending on your data) to
double check. If this results in a map that's not blank, you just need to set
the default style for your layer to something more appropriate.
Hope this helps,
David Winslow
On Thursday 10 July 2008 11:01:47 shadow_phoenix wrote:
Hello
and I can creste festuretypes without any problem, but when I try to see
the map in the demo I only get a blank map. The bbox is the one generated
by the rpogram.
Can anyone help me?
Thank you
iI have met the same question.
David Winslow-5 wrote:
Hi,I have tried it using the default style,but it did nothing
can anyone help me?
thanks
to
Please
set
Hope this helps,
David Winslow
Hello
by the rpogram.
Can anyone help me?
Thank you
Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
Studies have shown that voting for your favorite open source project,
along with a healthy diet, reduces your potential for chronic lameness
and boredom. Vote Now at http://www.sourceforge.net/community/cca08
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Oracle-%2B-Geoserver-%3D-Blank-tp18384829p18526989.html
Hvae you solved your problem?
I also meet the same problem.
Hello
by the rpogram.
Can anyone help me?
Thank you
View this message in context: http://www.nabble.com/Oracle-%2B-Geoserver-%3D-Blank-tp18384829p18560455.html
