[Geoserver-users] Oracle layer cannot be saved
Hello,
In geoserver 2.5.2 I have an oracle datastore. I can see alle tables of the specified schema. When I try to add a new oracle layer (by clicking ‘publish’) and save the layer in the layer properties screen, nothing happens. Layer is not added, no error. What can be the problem?
Thanks.
Erik-Jan Martens
Geo-informatiebeheerder
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@anonymised.com
2015-03-25 12:49 GMT+01:00 Erik Jan Martens <E.Martens@anonymised.com>:
Hello,
Did you check the GeoServer log?
Any clue for the issue?
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Hi Stefano,
Thanks for the reply.
This is in my Geoserver.log. Don’t know what it means. BAG_B is the oracle datastore. Any Idea?
015-03-25 12:25:31,434 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2015-03-25 12:25:31,434 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down…
2015-03-25 12:25:31,449 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor…
2015-03-25 12:25:31,449 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor…
2015-03-25 12:25:31,449 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
2015-03-25 12:25:31,449 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor…
2015-03-25 12:25:31,449 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
2015-03-25 12:25:31,449 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks…
2015-03-25 12:25:31,449 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2015-03-25 12:25:31,449 INFO [storage.DefaultStorageBroker] - Destroying StorageBroker
2015-03-25 12:25:31,449 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘GWCLifeCycleHandler’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2015-03-25 12:26:17,418 WARN [geoserver.global] - Found System environment variable GEOSERVER_DATA_DIR set to C:\Program Files (x86)\GeoServer 2.5.2\data_dir , but this path does not exist
2015-03-25 12:26:17,418 INFO [geoserver.global] - Falling back to embedded data directory: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
2015-03-25 12:26:18,246 WARN [geoserver.global] - Found System environment variable GEOSERVER_DATA_DIR set to C:\Program Files (x86)\GeoServer 2.5.2\data_dir , but this path does not exist
2015-03-25 12:26:18,262 INFO [geoserver.global] - Falling back to embedded data directory: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
2015-03-25 12:49 GMT+01:00 Erik Jan Martens <E.Martens@…6988…>:
Hello,
Stefano
41.95581N 12.52854E
