[Geoserver-users] Oracle layer cannot be saved
2015-03-25 12:26:27,465 ERROR [storage.DefaultStorageFinder] - Found System environment variable GEOSERVER_DATA_DIR set to C:\Program Files (x86)\GeoServer 2.5.2\data_dir , but this path does not exist
I think that very first you must correct this. Saving new settings to non-existing data_dir likely fails.
-Jukka Rahkonen-
Erik Jan Martens wrote:
Hi Stefano,
Thanks for the reply.
This is in my Geoserver.log. Don’t know what it means. BAG_B is the oracle datastore. Any Idea?
015-03-25 12:25:31,434 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2015-03-25 12:25:31,434 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down…
2015-03-25 12:25:31,449 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor…
2015-03-25 12:25:31,449 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor…
2015-03-25 12:25:31,449 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
2015-03-25 12:25:31,449 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor…
2015-03-25 12:25:31,449 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
2015-03-25 12:25:31,449 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks…
2015-03-25 12:25:31,449 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2015-03-25 12:25:31,449 INFO [storage.DefaultStorageBroker] - Destroying StorageBroker
2015-03-25 12:25:31,449 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘GWCLifeCycleHandler’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2015-03-25 12:26:17,418 WARN [geoserver.global] - Found System environment variable GEOSERVER_DATA_DIR set to C:\Program Files (x86)\GeoServer 2.5.2\data_dir , but this path does not exist
2015-03-25 12:26:17,418 INFO [geoserver.global] - Falling back to embedded data directory: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
2015-03-25 12:26:18,246 WARN [geoserver.global] - Found System environment variable GEOSERVER_DATA_DIR set to C:\Program Files (x86)\GeoServer 2.5.2\data_dir , but this path does not exist
2015-03-25 12:26:18,262 INFO [geoserver.global] - Falling back to embedded data directory: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
  • GEOSERVER_DATA_DIR: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘burg’
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘capitals’
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘cite_lakes’
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘dem’
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘giant_polygon’
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘grass’
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘green’
2015-03-25 12:26:18,621 INFO [org.geoserver] - Loaded style ‘line’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘poi’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘point’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘polygon’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘pophatch’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘population’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘rain’
2015-03-25 12:26:18,637 INFO [org.geoserver] - Loaded style ‘raster’
2015-03-25 12:26:18,652 INFO [org.geoserver] - Loaded style ‘restricted’
2015-03-25 12:26:18,652 INFO [org.geoserver] - Loaded style ‘simple_roads’
2015-03-25 12:26:18,652 INFO [org.geoserver] - Loaded style ‘simple_streams’
2015-03-25 12:26:18,652 INFO [org.geoserver] - Loaded style ‘tiger_roads’
2015-03-25 12:26:18,652 INFO [org.geoserver] - Loaded default workspace BAG_BRG
2015-03-25 12:26:18,668 INFO [org.geoserver] - Loaded workspace ‘BAG_BRG’
2015-03-25 12:26:18,668 INFO [org.geoserver] - Loaded workspace ‘riool’
2015-03-25 12:26:20,027 INFO [org.geoserver] - Loaded store ‘BAGBERGEIJK’, enabled
2015-03-25 12:26:20,027 INFO [org.geoserver] - Loaded data store ‘BAGBERGEIJK’
2015-03-25 12:26:21,199 INFO [org.geoserver] - Loaded store ‘Riool_Data’, enabled
2015-03-25 12:26:21,199 INFO [org.geoserver] - Loaded data store ‘Riool_Data’
2015-03-25 12:26:22,621 INFO [org.geoserver] - Loaded feature type ‘GMSP_ON_LEIDING_M1’, enabled
2015-03-25 12:26:22,715 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 12:26:22,746 INFO [org.geoserver] - Loaded layer ‘GMSP_ON_LEIDING_M1’
2015-03-25 12:26:22,762 INFO [org.geoserver] - Loaded feature type ‘GMSP_PUT2_ST’, enabled
2015-03-25 12:26:22,762 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 12:26:22,777 INFO [org.geoserver] - Loaded layer ‘GMSP_PUT2_ST’
2015-03-25 12:26:22,777 INFO [org.geoserver] - Loaded feature type ‘GMSP_RL_VOORZ_M2’, enabled
2015-03-25 12:26:22,777 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 12:26:22,793 INFO [org.geoserver] - Loaded layer ‘GMSP_RL_VOORZ_M2’
2015-03-25 12:26:22,793 INFO [org.geoserver] - Loaded feature type ‘GMSP_STRENG1_M1’, enabled
2015-03-25 12:26:22,793 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 12:26:22,793 INFO [org.geoserver] - Loaded layer ‘GMSP_STRENG1_M1’
2015-03-25 12:26:27,199 INFO [org.geoserver] - Loaded layer group ‘Rioolgroep’
2015-03-25 12:26:27,465 INFO [storage.DefaultStorageFinder] - ******************************************************************************************************
2015-03-25 12:26:27,465 INFO [storage.DefaultStorageFinder] - *** Found System environment variable TEMP set to C:\Windows\TEMP, using it as the default prefix. ***
2015-03-25 12:26:27,465 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in ‘C:\Windows\TEMP\geowebcache’
2015-03-25 12:26:27,809 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
2015-03-25 12:26:27,809 INFO [gwc.layer] - GeoServer TileLayer store base directory is: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc-layers
2015-03-25 12:26:27,809 INFO [gwc.layer] - Loading tile layers from C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc-layers
2015-03-25 12:26:27,934 INFO [gwc.layer] - GWC configuration based on GeoServer’s Catalog loaded successfuly
2015-03-25 12:26:27,934 INFO [config.XMLConfiguration] - Found configuration file in C:\Windows\TEMP\geowebcache
2015-03-25 12:26:28,027 WARN [config.XMLConfiguration] - ********************************************************************************
2015-03-25 12:26:28,027 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: Cannot find the declaration of element ‘gwcConfiguration’.
2015-03-25 12:26:28,027 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
2015-03-25 12:26:28,043 INFO [config.XMLConfiguration] - Initializing GridSets from C:\Windows\TEMP\geowebcache
2015-03-25 12:26:28,074 INFO [config.XMLConfiguration] - Initializing layers from C:\Windows\TEMP\geowebcache
2015-03-25 12:26:28,074 INFO [layer.TileLayerDispatcher] - Configuration C:\Windows\TEMP\geowebcache contained no layers.
2015-03-25 12:26:28,121 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: C:\Windows\TEMP\geowebcache\geowebcache-diskquota.xml
2015-03-25 12:26:28,137 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2015-03-25 12:26:28,137 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2015-03-25 12:26:28,137 INFO [diskquota.DiskQuotaMonitor] - 5 layers attached to global quota 500,0 MB
2015-03-25 12:26:28,152 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2015-03-25 12:26:28,215 WARN [gwc.layer] - Can’t compute bounds for tile layer riool:GMSP_ON_LEIDING_M1 in CRS EPSG:900913. Assuming full GridSet bounds. (null)
2015-03-25 12:26:28,246 WARN [gwc.layer] - Can’t compute bounds for tile layer riool:GMSP_ON_LEIDING_M1 in CRS EPSG:4326. Assuming full GridSet bounds. (null)
2015-03-25 12:26:28,371 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
2015-03-25 12:26:28,543 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
2015-03-25 12:26:28,606 INFO [org.geoserver] - Loaded service ‘wms’, enabled
2015-03-25 12:26:28,606 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2015-03-25 12:26:28,840 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler ‘dispatcher’
2015-03-25 12:26:28,981 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2015-03-25 12:26:29,199 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 14 paths
2015-03-25 12:26:29,434 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2015-03-25 12:26:29,434 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2015-03-25 12:26:30,215 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2015-03-25 12:26:30,246 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2015-03-25 12:26:32,902 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/icon/**/*] onto handler ‘kmlIconService’
2015-03-25 12:26:32,902 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler ‘dispatcher’
2015-03-25 12:26:32,902 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
2015-03-25 12:26:33,074 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler ‘dispatcher’
2015-03-25 12:26:33,074 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
2015-03-25 12:26:34,215 INFO [org.geoserver] - GeoServer configuration lock is enabled
2015-03-25 12:26:34,496 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler ‘dispatcher’
2015-03-25 12:26:34,512 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
2015-03-25 12:26:44,152 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler ‘dispatcher’
2015-03-25 12:26:44,152 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
2015-03-25 12:26:44,152 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
2015-03-25 12:27:01,606 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
2015-03-25 12:27:01,606 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler ‘dispatcher’
2015-03-25 12:27:01,715 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2015-03-25 12:27:01,715 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler ‘dispatcher’
2015-03-25 12:38:37,840 WARN [geoserver.security] - Strong cryptography is NOT available
Download and installation the of unlimted length policy files is recommended
2015-03-25 12:42:04,887 INFO [geoserver.catalog] - Disposing datastore ‘BAG_B’
2015-03-25 12:42:05,043 INFO [geoserver.catalog] - Disposing datastore ‘BAG_B’
Met vriendelijke groet,
Erik-Jan Martens
Geo-informatiebeheerder
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@…6988…
Van: Stefano Iacovella [mailto:stefano.iacovella@…84…]
Verzonden: woensdag 25 maart 2015 13:02
Aan: Erik Jan Martens
CC: geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] Oracle layer cannot be saved
2015-03-25 12:49 GMT+01:00 Erik Jan Martens <E.Martens@…6988…>:
Hello,
In geoserver 2.5.2 I have an oracle datastore. I can see alle tables of the specified schema. When I try to add a new oracle layer (by clicking ‘publish’) and save the layer in the layer properties screen, nothing happens. Layer is not added, no error. What can be the problem?
Did you check the GeoServer log?
Any clue for the issue?
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
Op dit bericht is een disclaimer van toepassing. De volledige tekst vindt u op:
http://www.kempengemeenten.nl/maildisclaimer
Thanks.
After changing the environment still no layer added. Logfile gives the following:
2015-03-25 13:35:41,324 INFO [georss.GeoRSSPoller] - destroy() invoked
2015-03-25 13:35:41,340 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
2015-03-25 13:35:41,356 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down…
2015-03-25 13:35:41,356 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor…
2015-03-25 13:35:41,356 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor…
2015-03-25 13:35:41,356 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
2015-03-25 13:35:41,356 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor…
2015-03-25 13:35:41,402 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
2015-03-25 13:35:41,402 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks…
2015-03-25 13:35:41,402 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
2015-03-25 13:35:41,402 INFO [storage.DefaultStorageBroker] - Destroying StorageBroker
2015-03-25 13:35:41,402 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘GWCLifeCycleHandler’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2015-03-25 13:36:21,934 INFO [geoserver.global] -
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘burg’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘capitals’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘cite_lakes’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘dem’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘giant_polygon’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘grass’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘green’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘line’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘poi’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘point’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘polygon’
2015-03-25 13:36:22,293 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
2015-03-25 13:36:22,309 INFO [org.geoserver] - Loaded style ‘pophatch’
2015-03-25 13:36:22,309 INFO [org.geoserver] - Loaded style ‘population’
2015-03-25 13:36:22,309 INFO [org.geoserver] - Loaded style ‘rain’
2015-03-25 13:36:22,309 INFO [org.geoserver] - Loaded style ‘raster’
2015-03-25 13:36:22,309 INFO [org.geoserver] - Loaded style ‘restricted’
2015-03-25 13:36:22,309 INFO [org.geoserver] - Loaded style ‘simple_roads’
2015-03-25 13:36:22,324 INFO [org.geoserver] - Loaded style ‘simple_streams’
2015-03-25 13:36:22,324 INFO [org.geoserver] - Loaded style ‘tiger_roads’
2015-03-25 13:36:22,324 INFO [org.geoserver] - Loaded default workspace BAG_BRG
2015-03-25 13:36:22,324 INFO [org.geoserver] - Loaded workspace ‘BAG_BRG’
2015-03-25 13:36:22,340 INFO [org.geoserver] - Loaded workspace ‘riool’
2015-03-25 13:36:23,637 INFO [org.geoserver] - Loaded store ‘BAGBERGEIJK’, enabled
2015-03-25 13:36:23,637 INFO [org.geoserver] - Loaded data store ‘BAGBERGEIJK’
2015-03-25 13:36:24,715 INFO [org.geoserver] - Loaded store ‘BAG_B’, enabled
2015-03-25 13:36:24,715 INFO [org.geoserver] - Loaded data store ‘BAG_B’
2015-03-25 13:36:25,012 INFO [org.geoserver] - Loaded store ‘Riool_Data’, enabled
2015-03-25 13:36:25,012 INFO [org.geoserver] - Loaded data store ‘Riool_Data’
2015-03-25 13:36:25,777 INFO [org.geoserver] - Loaded feature type ‘GMSP_ON_LEIDING_M1’, enabled
2015-03-25 13:36:25,793 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 13:36:25,840 INFO [org.geoserver] - Loaded layer ‘GMSP_ON_LEIDING_M1’
2015-03-25 13:36:25,840 INFO [org.geoserver] - Loaded feature type ‘GMSP_PUT2_ST’, enabled
2015-03-25 13:36:25,840 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 13:36:25,840 INFO [org.geoserver] - Loaded layer ‘GMSP_PUT2_ST’
2015-03-25 13:36:25,840 INFO [org.geoserver] - Loaded feature type ‘GMSP_RL_VOORZ_M2’, enabled
2015-03-25 13:36:25,856 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 13:36:25,856 INFO [org.geoserver] - Loaded layer ‘GMSP_RL_VOORZ_M2’
2015-03-25 13:36:25,871 INFO [org.geoserver] - Loaded feature type ‘GMSP_STRENG1_M1’, enabled
2015-03-25 13:36:25,871 INFO [org.geoserver] - Loaded feature type ‘Riool_Data’
2015-03-25 13:36:25,871 INFO [org.geoserver] - Loaded layer ‘GMSP_STRENG1_M1’
2015-03-25 13:36:30,309 INFO [org.geoserver] - Loaded layer group ‘Rioolgroep’
2015-03-25 13:36:30,590 INFO [storage.DefaultStorageFinder] - **********************************************************************************************************************************************************************************
2015-03-25 13:36:30,590 INFO [storage.DefaultStorageFinder] - *** Found System environment variable GEOSERVER_DATA_DIR set to C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data, using it as the default prefix. ***
2015-03-25 13:36:30,590 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in ‘C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc’
2015-03-25 13:36:30,965 INFO [gwc.layer] - Initializing GWC configuration based on GeoServer’s Catalog
2015-03-25 13:36:30,965 INFO [gwc.layer] - GeoServer TileLayer store base directory is: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc-layers
2015-03-25 13:36:30,965 INFO [gwc.layer] - Loading tile layers from C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc-layers
2015-03-25 13:36:31,074 INFO [gwc.layer] - GWC configuration based on GeoServer’s Catalog loaded successfuly
2015-03-25 13:36:31,168 WARN [config.XMLConfiguration] - Found no configuration file in config directory, will create one at ‘C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc\geowebcache.xml’ from template jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%208.0/webapps/geoserver/WEB-INF/lib/gwc-core-1.5.3.jar!/geowebcache_empty.xml
2015-03-25 13:36:31,277 WARN [config.XMLConfiguration] - ********************************************************************************
2015-03-25 13:36:31,277 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: Cannot find the declaration of element ‘gwcConfiguration’.
2015-03-25 13:36:31,277 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
2015-03-25 13:36:31,293 INFO [config.XMLConfiguration] - Initializing GridSets from C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc
2015-03-25 13:36:31,293 INFO [config.XMLConfiguration] - Initializing layers from C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc
2015-03-25 13:36:31,293 INFO [layer.TileLayerDispatcher] - Configuration C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc contained no layers.
2015-03-25 13:36:31,340 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc\geowebcache-diskquota.xml
2015-03-25 13:36:31,356 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2015-03-25 13:36:31,356 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2015-03-25 13:36:31,356 INFO [diskquota.DiskQuotaMonitor] - 5 layers attached to global quota 500,0 MB
2015-03-25 13:36:31,371 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2015-03-25 13:36:31,496 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
2015-03-25 13:36:31,527 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
2015-03-25 13:36:31,621 INFO [org.geoserver] - Loaded service ‘wms’, enabled
2015-03-25 13:36:31,637 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2015-03-25 13:36:31,981 INFO [ows.OWSHandlerMapping] - Mapped URL path [/gwc/service/**] onto handler ‘dispatcher’
2015-03-25 13:36:32,012 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2015-03-25 13:36:32,231 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 14 paths
2015-03-25 13:36:32,246 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job…
2015-03-25 13:36:32,246 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2015-03-25 13:36:34,199 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2015-03-25 13:36:34,199 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2015-03-25 13:36:36,996 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/icon/**/*] onto handler ‘kmlIconService’
2015-03-25 13:36:36,996 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml/*] onto handler ‘dispatcher’
2015-03-25 13:36:36,996 INFO [ows.OWSHandlerMapping] - Mapped URL path [/kml] onto handler ‘dispatcher’
2015-03-25 13:36:37,293 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows/**] onto handler ‘dispatcher’
2015-03-25 13:36:37,293 INFO [ows.OWSHandlerMapping] - Mapped URL path [/ows] onto handler ‘dispatcher’
2015-03-25 13:36:37,309 INFO [org.geoserver] - GeoServer configuration lock is enabled
2015-03-25 13:36:37,590 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler ‘dispatcher’
2015-03-25 13:36:37,590 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
2015-03-25 13:36:47,652 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler ‘dispatcher’
2015-03-25 13:36:47,652 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
2015-03-25 13:36:47,652 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
2015-03-25 13:37:05,277 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
2015-03-25 13:37:05,277 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler ‘dispatcher’
2015-03-25 13:37:05,418 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2015-03-25 13:37:05,418 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler ‘dispatcher’
2015-03-25 13:43:36,324 WARN [geoserver.security] - Strong cryptography is NOT available
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Van: Rahkonen Jukka (MML) [mailto:jukka.rahkonen@…6847…]
Verzonden: woensdag 25 maart 2015 13:19
Aan: Erik Jan Martens; ‘Stefano Iacovella’
-Jukka Rahkonen-
Hi Stefano,
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Hello,
Stefano
41.95581N 12.52854E
I can’t see any record about adding the layer, did you extracted the log after trying to configure and save the layer?
You could also try to switch to a more detailed level.
2015-03-25 14:03 GMT+01:00 Erik Jan Martens <E.Martens@anonymised.com>:
Thanks.
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@anonymised.com
Van: Rahkonen Jukka (MML) [mailto:jukka.rahkonen@anonymised.com]
-Jukka Rahkonen-
Hi Stefano,
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@anonymised.com…
Van: Stefano Iacovella [mailto:stefano.iacovella@anonymised.com]
2015-03-25 12:49 GMT+01:00 Erik Jan Martens <E.Martens@anonymised.com>:
Hello,
Stefano
41.95581N 12.52854E
41.95581N 12.52854E
