Noticed something more:
In my wfs request if use two layers (so typename=layer1,layer2)
When setting maxfeatures to Integer.MAX_VALUE (eq 2147483647)
I see the first query not using rownum at all and the second one uses
rownum <= 2147483646
So somewhere down the line the value of maxfeatures is decreased with 1)
The same goes for the two sdo_agr_mbr queries
So disabling the maxfeatures can be done by setting it to
Integer.MAX_VALUE.
Should I still create an issue for this??
I also noticed the count statements are from a getServiceInfo request.
What's that??
Kris
-----Original Message-----
From: Kris Geusebroek [mailto:kgeusebroek@anonymised.com]
Sent: Wednesday, March 25, 2009 11:39 AM
To: Andrea Aime
Subject: Re: [Geoserver-users] Oracle NG and maxFeatures
You're right about the effect on performance the rownum query isn't
noticeably slower (I think because of oracle optimalization)
I tried the MAX_VALUE, but since the rownum is set to be <= (then the
value set minus 1) I'm left with the rownum <= 2147483646, just like
when I removed the maxfeatures from settings.xml completely.
I will create a issue for the enabling/disabling of the maxfeatures
setting
I didn't have the featurebounds setting in services.xml, but even when
setting it explicitly to false I keep getting the sdo_agg_mbr queries
executed after the feature select queries.
I'm issueing a request with version=1.0.0 so it suproses me to see the
count query at all.
And since the maxfeatures cannot be disabled right now I've set them to
1000 and I see the normal query for getting the features uses rownum <=
1000
But the sdo_agr_mbr one uses rownum <= 988
Question remains how to disable the bounds query since I don't need the
bounds in my result
And I can imagine the performance gain when getting rid of these 2 extra
queries.
Thanks in advance
Kris
Sent: Wednesday, March 25, 2009 11:22 AM
To: Kris Geusebroek
Kris Geusebroek ha scritto:
I want to get rid of the rownum <= 999999 construct in my queries.
I don't have a lot of data so this is not needed for me.
Have you checked, does it negatively affect the performance
of your queries? Given the time we spend doing just xml encoding
I would be surprise it has any user noticeable effect.
I thought it was related to the maxfeatures setting in services.xml
(which is set to 1000000) so I removed this but now ended up in
Rownum = 2147483646 (1 less then Integer.MAX_VALUE).
I can see code that checks if limits can be set that checks if
maxfeatures is set. This code checks against Integer.MAX_VALUE.
I tried setting the services.xml value to 2147483648 but that gives an
exception on reloading the settings. (not an integer, which is correct
Have you tried with MAX_VALUE exactly? 2147483647
Anyways, can you open a feature request on jira.codehaus.org
to have the maxFeature setting easier to disable (like, a checkbox to
control if maxFeature is set at all?)?
I think the oracle NG plugin is also creating extra queries (GT_BOUNDS
and GT_COUNT) dependant of this maxfeatures setting.
I see the select count(*) .... GT_COUNT_
Then the normal select query to get the features
And then an select sdo_aggr_mbr ........ which aggregates the
geometrys
How can I get rid of these extra queries, or are they needed for some
special functionality.
These are issued to generate the feature collection bounds and count
for WFS 1.1 request (WFS 1.0 requests should issue only the bounds one).
And the bounds are generated only if the WFS configuration says so, try
to disable "feature bounding" and those queries should go away in
the WFS 1.0 case (the count one will remain for the WFS 1.1 case).
Andrea Aime
OpenGeo - http://opengeo.org
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based
development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
