[Geoserver-users] Oracle OCI install
Hi All,
I've installed the binary package of Geoserver 1.7.2 on Ubuntu Linux
8.10 with Sun JDK 1.6.0_10. It is up and working, but I need to
connect it to an Oracle database. I want to use OCI, which is also up
and successfully used by Mapserver. I tried to symlink OCI's
ojdbc6.jar into geoserver/webapps/geoserver/WEB-INF/lib directory, but
no effect (not any Oracle option appears in
Welcome | Config | Data | DataStores | New page's Feature Data Set
Description dropdown list). I've restarted Geoserver, it starts
without any related ERROR, WARN, FATAL message in its log. Logging is
set to some debug level, so quite long.
related environment variables:
JAVA_HOME=/usr/lib/jvm/java-6-sun
ORACLE_BASE=/usr/local/instantclient_11_1
ORACLE_HOME=/usr/local/instantclient_11_1
ORACLE_SID=XE
GEOSERVER_DATA_DIR=/var/lib/geoserver_data
GEOSERVER_HOME=/usr/local/geoserver-1.7.2
What did I wrong?
Thank you in advance!
Best regards: Balázs Bámer
Hi Balázs,
Just a point of clarification. Did you install the oracle extension before symlinking the ojdbc6.jar? If so, does it show up as an available data store if you do not symlink the jar?
-Justin
Balázs Bámer wrote:
Hi All,
ORACLE_SID=XE
What did I wrong?
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
