[Geoserver-users] Oracle Spatial, GoogleMaps, GeoServer and the Netherlands projection
I am trying to do an overlay of Oracle Spatial data in the Netherlands projection system - 28992.
This issue was discussed on this forum in February 2007 (not specifically related to Oracle Spatial) and it was then suggested to upgrade to 1.5 and this solved the problem.
I am however using GeoServer 1.6 and I still get the error reported then: “(about 80 meters north and twenty east)”.
I think I might need to change the projection in Oracle - I am using 90112.
Pieter
Pieter Minnaar ha scritto:
I am however using GeoServer 1.6 and I still get the error reported then: "(about 80 meters north and twenty east)".
Hum, GeoServer is now using the official EPSG database for SRS
lookup, so it should be picking the most accurate set of parameters.
What SRS handling have you chosen for your feature type? Force or
reproject? Try playing with that setting.
Which is an Oracle custom projection, not a standard one.
Would you be able to dump your data into a shapefile and send it to me
by private mail? This way I can have a look.
Also, what are you using as a term of comparison for the offsets?
Google Earth?
