[Geoserver-users] Oracle store table list
Hi list,
I’ve created an Oracle store using Oracle NG. This works, however when I go to layers and use this store, it lists 2098 items. There are only 928 tables that the user has access to.
It seems to have included all manner of system tables, such as “ALL_COL_PRIVS” etc. I can’t conceive of why anyone would want to publish those sorts of things via GeoServer, so shouldn’t it just list the actual tables that user has access to?
http://stackoverflow.com/questions/205736/oracle-get-list-of-all-tables - advises how to get all tables. I’d suggest using a slightly amended version of the second one:
select TABLE_NAME from all_tables where TABLE_NAME NOT LIKE ‘MDRT_%’
Tables begining MDRT _ are Oracle spatial indices and can be ignored safely.
Or is there a reason for the list that GeoServer currently uses?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
