[Geoserver-users] Oracle view doesn't usw spatial index
You should first test the view directly in Oracle with a bounding box and ANY_INTERACTION query. If such query is fast, change the logging level of your Geoserver into geotools developer, catch the SQL that Geoserver is generating and run queries directly from Oracle. You may find something interesting even the test is not totally reliable because Geoserver is using prepared statements and running the extracted SQL with SQL Plus is not exactly the same thing.
One quick test would be to remove first separately and then both "where year=2016" and "where geom is not null". Oracle optimizer is sometimes making odd decisions.
-Jukka Rahkonen-
________________________________________
fmd85@anonymised.com wrote:
no, my Select-Statement in the view is just sth. like 'select column abc as XY, select column bcd as XZ where year=2016 and geom is not null'.
The rights don't seem to be a problem, since i have also tried to use the DBA-Account with no success.
I'm using OJDBC7.jar as the driver (OJDBC6.jar was also tested).
<quote author='Rahkonen Jukka (MML)'>
If the view makes simple "SELECT geometry, other_stuff WHERE..." the spatial
index works transparently for us. We do not run 2.9, though. Do you use some
more advanced SQL in your views? Also giving GRANT SELECT ON VIEW for the
geoserver user may not be enough but your user seems to have good rights
because normat tables work fine.
-Jukka Rahkonen-
Lähettäjä: fmd.85 <fmd85@anonymised.com>
Lähetetty: 27. heinäkuuta 2016 10:07
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] Oracle view doesn't usw spatial index
I'm using geoserver 2.9.0 with the oracle plugin and try to publish a layer
of a view. I created the View in the database and in Geosever (add new layer
-> create view) with the same results.
The original table in the database has a spatial index and publishing the
table directly works fine. If i use any kind of view, the spatial index of
the table seems to be ignored. Even the computation of the Bounding Box
takes ~30 minutes (with an index ~15 seconds).
Does anyone else have the same problem? Any suggestions how to solve this
problem? Creating materialized views for each table is no option for me
since i'm running out of table space.
Max
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Oracle-view-doesn-t-usw-spatial-index-tp5278308.html
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning
reports.http://sdm.link/zohodev2dev
Geoserver-users mailing list
planning
</quote>
Quoted from:
http://osgeo-org.1560.x6.nabble.com/Oracle-view-doesn-t-use-spatial-index-tp5278308p5278311.html
Sent from http://osgeo-org.1560.x6.nabble.com
Hey,
I just stumbled into this interesting article:
https://oracle-base.com/articles/11g/adaptive-cursor-sharing-11gr1
It would seem Oracle could be made smarter in its plan choice, but one has to tell it explicitly to be with a query hint?? :slight_smile:
I don’t have time/mandate to work on this, but it could be useful to anyone that does.
On Wed, Jul 27, 2016 at 11:41 AM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
One quick test would be to remove first separately and then both “where year=2016” and “where geom is not null”. Oracle optimizer is sometimes making odd decisions.
-Jukka Rahkonen-
no, my Select-Statement in the view is just sth. like ‘select column abc as XY, select column bcd as XZ where year=2016 and geom is not null’.
The rights don’t seem to be a problem, since i have also tried to use the DBA-Account with no success.
I’m using OJDBC7.jar as the driver (OJDBC6.jar was also tested).
If the view makes simple “SELECT geometry, other_stuff WHERE…” the spatial
-Jukka Rahkonen-
Aihe: [Geoserver-users] Oracle view doesn’t usw spatial index
I’m using geoserver 2.9.0 with the oracle plugin and try to publish a layer
→ create view) with the same results.
since i’m running out of table space.
Max
planning
planning
Quoted from: [http://osgeo-org.1560.x6.nabble.com/Oracle-view-doesn-t-use-spatial-index-tp5278308p5278311.html](http://osgeo-org.1560.x6.nabble.com/Oracle-view-doesn-t-use-spatial-index-tp5278308p5278311.html)
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
