We have a table that includes X and Y columns for latitude and longitudes. We created a view with geom column from this table as follows :
(SDO_GEOMETRY(2001, 4326, SDO_POINT_TYPE (ST.Y, ST.X, NULL), NULL, NULL))
Then we published this view from GeoServer and try to get the WMS request.
The WMS request has following error :
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
Rendering process failed
java.io.IOExceptionORA-13226: interface not supported without a spatial index
ORA-06512: at "MDSYS.MD", line 1723
ORA-06512: at "MDSYS.MDERR", line 8
ORA-06512: at "MDSYS.SDO_3GL", line 88
As far as I searched, this was a problem in Oracle 9, but we are working on 11g.
How can we get rid of this error? There was no luck with creating spatial index on views.
Best.
A.
Hi Alper,
nope, as far as I know, the problem is still there, known issue, we cannot query
data that does not have a spatial index:
https://osgeo-org.atlassian.net/browse/GEOT-4768
Some development is needed to recognize the source has no spatial indexes,
and change the spatial operators we use for bbox queries
On Wed, May 13, 2015 at 4:10 PM, Alper Dinçer <alperd.web@anonymised.com> wrote:
Best.
A.
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Have you tried creating a spatial function-based index on the table?
http://docs.oracle.com/cd/E11882_01/appdev.112/e11830/sdo_exten.htm#SPATL799
See the example 9.2.1 - it creates a function creating the geometry out of the X,Y values, and then uses that for indexing and querying. Hopefully it’s possible to define a view hiding the existence of the function, but still using the spatial index. In this case, GeoServer might be able to query the view (using SDO_FILTER as per normal) and Oracle will support the query since it can use the index.
Ironically, in my experience when working with tables containing XY data, it’s at least as fast to simply use normal B-tree indexes and range queries. However, it doesn’t sound like this can be made to work in GeoServer (yet…)
On Wed, May 13, 2015 at 7:10 AM, Alper Dinçer <alperd.web@anonymised.com> wrote:
Best.
A.
Also see this page, which gives a good example of using the function-based index technique:
http://gis.stackexchange.com/questions/92554/can-i-create-an-oracle-spatial-view-from-a-non-spatial-table
That page also mentions the possiblity of defining a materialized view on the underlying table, which should be able to support a spatial index directly.
On Wed, May 13, 2015 at 9:27 AM, Martin Davis <mtnclimb@anonymised.com> wrote:
