Hi list,
we just upgraded from 1.3.0 to 1.3.4 and Oracle views don't work anymore.
There is always a SELECT "null" in the SQL statement when do perform a
GetFeature request.
Any ideas what could be causing this?
Caused by: org.geotools.data.DataSourceException: Error Performing SQL
query: SELECT "null", "OGR_FID", "ORA_GEOM
ETRY", "WEGNUMMER", "HECTOMTRNG_ORG", "HECTOMTRNG" FROM "V_HECTOPUNTEN"
at
org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:927)
at
org.geotools.data.jdbc.JDBC1DataStore.getFeatureReader(JDBC1DataStore.java:666)
at
org.geotools.data.jdbc.JDBCFeatureCollection.reader(JDBCFeatureCollection.java:78)
at
org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:396)
... 31 more
Caused by: java.sql.SQLException: ORA-00904: "null": invalid identifier
at
oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at
oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java(Compiled
Code))
at
oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:598)
at
oracle.jdbc.driver.T2CStatement.executeForDescribe(T2CStatement.java:778)
at
oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1039)
at
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1132)
at
oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1272)
at
org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:916)
... 34 more
Best regards,
Bart
Bart van den Eijnden (OSGIS) wrote:
Hi list,
GetFeature request.
I'm experiencing the same on DB2 with latest WCS branch see my "View as featuretypes on DB2" post.
Luca Morandini
www.lucamorandini.it
Hi list,
GetFeature request.
hmmm... maybe it misses a PK: try something like:
ALTER VIEW myview ADD CONSTRAINT myview_PK PRIMARY KEY(mycolumn) DISABLE NOVALIDATE;
Luca Morandini
Just found out there is a new requirement apparently, if I define a
primary key constraint on my view it works again.
Example SQL for Oracle:
CREATE OR REPLACE VIEW V_KMMARKERINGEN
("OGR_FID","ORA_GEOMETRY","VWK_ID","VWK_BEGDTM","POS_TOV_AS","GTLWAARDE","LTRWAARDE","AFSTAND","MST_CODE","VWG_NAAM"
UNIQUE RELY DISABLE NOVALIDATE,
CONSTRAINT PK_V_KMMARKERINGEN
PRIMARY KEY (OGR_FID) RELY DISABLE NOVALIDATE) AS
(SELECT
FROM KMMARKERINGEN) ORDER BY VWG_NAAM, GTLWAARDE
Best regards,
Bart
Hi list,
anymore.
GetFeature request.
Luca Morandini
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-users mailing list
Something happened in GeoTools used between Geoserver 1.3.0 and 1.4 which causes a NullFIDMapper to return a key column name of "null" and also decide to use this as a selected column name.
I have a fix for DB2 but the change needs to be made higher in the class hierarchy which will probably fix the problem for Oracle as well.
What level of GeoTools is currently being used by GeoServer? I'm working with the GeoTools 2.2.x code tree.
David
> Hi list,
> GetFeature request.
Luca Morandini
It'd be great to have that fix. GeoServer 1.3.1+ and 1.4.x are all built on geotools 2.2.x.
Be sure to commit to trunk as well though, so that we don't have the problem pop up again.
best regards,
Chris
David
Hi list,
GetFeature request.
Luca Morandini
!DSPAM:1003,4522ad2c223494750375898!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
AFAIK, the WCS branch is built using 2.3-SNAPSHOT.
Luca Morandini
