[Geoserver-users] Oracle XDB Error
I am trying to setup WFS on GeoServer 2.5.1 using the oracle plugin and I am running into the error below.
Error is java.lang.NoClassDefFoundError: oracle/xdb/XMLType oracle/xdb/XMLType oracle.xdb.XMLType
I have the copied the sdb6 and ojdbc6 jar files from oracles into the web-inf/lib directory and I am still hitting the issue. Has anyone else experienced this issue.
Thanks
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
On Mon, Jul 14, 2014 at 4:59 PM, Price, Robert C. <RCPRICE@anonymised.com> wrote:
It would be nice to see the full error (stack trace) found in the geoserver
logs.
That said, GeoServer does not support Oracle XML type (adding meaningful
support for
it would make for an interesting discussion)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I added the sdb.jar file to the web-inf/lib folder on my locl geoserver since it contains the oracle/xdb/XMLType classes but I still receive the error.
Download and install of policy files recommended
from http://www.oracle.com/technetwork/java/javase/downloads/jce-6-download-429243.html
2014-07-17 08:42:36,755 INFO [geoserver.wfs] -
Request: getServiceInfo
2014-07-17 08:42:36,930 INFO [geoserver.wfs] -
Request: getFeature
service = WFS
version = 1.0.0
baseUrl = http://localhost:2000/geoserver/
query[0]:
typeName[0] = {http://www.opengeospatial.net/cite}testbuoy
maxFeatures = 50
outputFormat = csv
resultType = results
2014-07-17 08:42:37,430 ERROR [geoserver.ows] -
at oracle.jdbc.driver.T4CTTIdcb.fillupPBAAccessors(T4CTTIdcb.java:914)
at oracle.jdbc.driver.T4CTTIdcb.fillupAccessors(T4CTTIdcb.java:304)
at oracle.jdbc.driver.T4CTTIdcb.receiveCommon(T4CTTIdcb.java:211)
at oracle.jdbc.driver.T4CTTIdcb.receive(T4CTTIdcb.java:149)
at oracle.jdbc.driver.T4C8Oall.readDCB(T4C8Oall.java:860)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:359)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:193)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:532)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:210)
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:1117)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1269)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1391)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3633)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3677)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1494)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:157)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:595)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:563)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:165)
at org.geoserver.feature.RetypingFeatureCollection.features(RetypingFeatureCollection.java:45)
at org.geoserver.feature.RetypingFeatureCollection.features(RetypingFeatureCollection.java:31)
at org.geoserver.wfs.response.CSVOutputFormat.write(CSVOutputFormat.java:138)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:190)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.ClassNotFoundException: oracle.xdb.XMLType
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
… 104 more
On Mon, Jul 14, 2014 at 4:59 PM, Price, Robert C. <RCPRICE@anonymised.com…> wrote:
It would be nice to see the full error (stack trace) found in the geoserver logs.
That said, GeoServer does not support Oracle XML type (adding meaningful support for
Ing. Andrea Aime
@geowolf
Technical Lead
