[Geoserver-users] org.geotools.data.DataSourceException: Could not count
Hello again!
I’ve just got another problem concerning “wfsGetFeature”-Request in Geoserver 1.3.3.
When I’m trying to request the Feature Infos from an Oracle-FeatureType (PUBLICTRAFFIC) I’m getting the following error message:
The LOG-File tells me:
cause: org.geotools.data.DataSourceException: Could not count
22.08.2006 09:44:21 org.vfny.geoserver.ServiceException getXmlResponse
WARNUNG: encountered error: org.geotools.data.DataSourceException: Could not count
StackTrace: org.geotools.data.DataSourceException: Could not count
at org.geotools.data.jdbc.JDBCFeatureSource.count(JDBCFeatureSource.java:336)
at org.geotools.data.jdbc.JDBCFeatureCollection.getCount(JDBCFeatureCollection.java:101)
at org.vfny.geoserver.wfs.responses.FeatureResponse.execute(FeatureResponse.java:327)
at org.vfny.geoserver.wfs.responses.FeatureResponse.execute(FeatureResponse.java:156)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:452)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:279)
at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doResponse(WfsDispatcher.java:284)
at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doGet(WfsDispatcher.java:213)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
at org.mortbay.http.HttpServer.service(HttpServer.java:879)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
Caused by: java.sql.SQLException: ORA-00921: unexpected end of SQL command
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:125)
at oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:681)
at oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:614)
at oracle.jdbc.driver.T2CStatement.execute_for_describe(T2CStatement.java:841)
at oracle.jdbc.driver.OracleStatement.execute_maybe_describe(OracleStatement.java:942)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1037)
at oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1183)
at org.geotools.data.jdbc.JDBCFeatureSource.count(JDBCFeatureSource.java:325)
… 25 more
22.08.2006 09:44:22 org.vfny.geoserver.ServiceException getXmlResponse
FEIN: return wfs exception is <?xml version="1.0" ?>
at org.mortbay.http.HttpServer.service(HttpServer.jav2.08.2006 09:44:20 org.vfny.geoserver.servlets.AbstractService init
INFO: Looking for configured service strategy PARTIAL-BUFFER
22.08.2006 09:44:20 org.vfny.geoserver.servlets.AbstractService init
INFO: Using service strategy class org.vfny.geoserver.servlets.PartialBufferStrategy
INFO: Set buffer size to 50
22.08.2006 09:44:21 org.vfny.geoserver.servlets.AbstractService doService
INFO: handling request:
Request: null
output format:GML2
max features:2147483647
version:
I read something about “too much open cursors” from MapServer to Oracle. Is there anything solved or is the problem still existing? Or is it another problem?
Any help is greatly appreciated.
Dirk
I think it's probably another problem. Could you set the logging level to 'fine' and include the text of the log file before the error? The error says there's something wrong with the sql statement, and attaching that should let us take a look at the statement.
thanks,
Chris
Dirk Buechel wrote:
Hello again!
I've just got another problem concerning "wfsGetFeature"-Request in Geoserver 1.3.3.
When I'm trying to request the Feature Infos from an Oracle-FeatureType (PUBLICTRAFFIC) I'm getting the following error message:
        ... 25 more
<ServiceExceptionReport
   version="1.2.0"
   xmlns="http://www.opengis.net/ogc&quot;
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
   xsi:schemaLocation="http://www.opengis.net/ogc http://mgv-nt18:80/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd&quot;&gt;
   <ServiceException>
Request: null
output format:GML2
version:
I read something about "too much open cursors" from MapServer to Oracle. Is there anything solved or is the problem still existing? Or is it another problem?
Dirk
<http://dict.tu-chemnitz.de/dings.cgi?o=3021;iservice=en-de;query=Your&gt; <http://dict.tu-chemnitz.de/dings.cgi?o=3021;iservice=en-de;query=help&gt; <http://dict.tu-chemnitz.de/dings.cgi?o=3021;iservice=en-de;query=is&gt; <http://dict.tu-chemnitz.de/dings.cgi?o=3021;iservice=en-de;query=greatly&gt; <http://dict.tu-chemnitz.de/dings.cgi?o=3021;iservice=en-de;query=appreciated&gt; !DSPAM:1003,44eab85e84092051017194!
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
