[Geoserver-users] OS SLD Vectormap district NamedPlaces fails to load into sld
I have been creating vectormap district in geoserver and styling it using the SLD files from the UK Ordnance Survey
When I tried to upload the sld for named places I get the following error :-
HTTP ERROR: 500
Form too large448874>200000
RequestURI=/geoserver/web/
It is very long but I am not sure if it’s even possible to split it and if I could can you assign 2 styles at the same time ?
Mark Ismail
Principal IT Officer
Tel: 0151 443 3021
Knowsley Council ê Westmorland Road ê Huyton ê L36 9GL
Save time – use the IT Service Desk Self Serve Application
Hi Mark,
This is because Jetty has a limit of the size of form you can upload to it.
See: http://stackoverflow.com/questions/3861455/form-too-large-exception
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
HTTP ERROR: 500
Mark Ismail
Tel: 0151 443 3021
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
Thanks Jonathan
I actually fixed the problem by uploading a small style with the named I wanted then using notepad on the server to add in the sld styles into the .sld
Mark Ismail
Tel: 0151 443 3021
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Sent: 01 May 2014 11:23
To: Ismail, Mark
Cc: geoserver mailing list (geoserver-users@lists.sourceforge.net)
Subject: Re: [Geoserver-users] OS SLD Vectormap district NamedPlaces fails to load into sld
Hi Mark,
Jonathan
HTTP ERROR: 500
Mark Ismail
Tel: 0151 443 3021
