is the OSM map on the website generated from Geoserver (geoserver.org)?
If so is the style (.sld) available?
Or there are other actual styles for OSM in Geoserver?
yobiSource
yobiSource
On Wed, Oct 22, 2014 at 12:03 PM, yobiSource <yobisource@anonymised.com> wrote:
You can get them here.
https://github.com/boundlessgeo/suite-data/tree/master/openstreetmap
In order to use them you’ll need to do some data prep, as described in the readme for that repository.
yobiSource
Geoserver-users mailing list
Geoserver-users@anonymised.comt
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com.
@boundlessgeo
