In Mac OSX Leopard I’ve defined a GEOSERVER_DATA_DIR Environment Variable pointing to a different directory then the default one inside the GeoServer 1.7.2 application package.
It won’t load on starting GeoServer 1.7.2. Instead, after starting the server through the menu, line 1 of the GeoServer screen still reads:
In Mac OSX Leopard I've defined a GEOSERVER_DATA_DIR Environment Variable pointing to a different directory then the default one inside the GeoServer 1.7.2 application package.
It won't load on starting GeoServer 1.7.2. Instead, after starting the server through the menu, line 1 of the GeoServer screen still reads:
- GEOSERVER_DATA_DIR: /Applications/GeoServer 1.7.2.app/Contents/Resources/Java/data_dir
Changing the web.xml file insite WEB-INF as a second method documented in the manual pages didn't solve this.
Is support for the DATA_DIR under Mac OSX already in place or planned for a future release?
Regards, Egbert
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Regards, Egbert
Justin Deoliveira
OpenGeo - http://opengeo.org
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
