[Geoserver-users] OutOfMemoryError for geoserver 2.2.1
Hi there,
I had Geoserver 2.1.1. installed and want to update on 2.2.1. (Tomcat6 on
Debian Sqeeze).
I saved Data-folder and then installed the geoserver.war file by restarting
tomcat. Data is easy to restore, so I do not really care, whether I loose it
or not.
Login as root (with pwd at masterpw.info) or admin (with geoserver)
succeeds, but then I sometimes achieve to change passwords bevor getting an
error, sometimes not.
In the Logfile I find the Error:
2012-11-30 10:47:55,551 ERROR [wicket.Session] - Exception when
detaching/serializing page
java.lang.OutOfMemoryError: PermGen space
Geoserver tells me: Sorry, your session timed out ...
RAM ist now 1GB, but I do not notice a difference in behaviour. Geoserver
2.2.1. on my machine seems to be much slower than 2.1.1.
Anything else I need to do or that I can check?
Thanks for your help.
Gabriele
View this message in context: http://osgeo-org.1560.n6.nabble.com/OutOfMemoryError-for-geoserver-2-2-1-tp5019827.html
http://docs.geoserver.org/stable/en/user/production/container.html
Try to set a bigger size for permanet generation
-XX:MaxPermSize=128m
as stated in the linked doc or higher
Kind Regards,
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2012/11/30 Gabriele Seitz <ml-seitz@anonymised.com>:
Hi there,
Debian Sqeeze).
or not.
Gabriele
Keep yourself connected to Go Parallel:
TUNE You got it built. Now make it sing. Tune shows you how.
http://goparallel.sourceforge.net
Geoserver-users mailing list
Gabriele,
the PermGenSpace contains the classes, configurations, data etc.i.e. the
program, the heap which you define with -Xmx and -Xmx contains the objects
at runtime i.e. the working program and is separate from the permanent
space. The classes or templates for the objects are taken from the
permanent space and put onto the heap filled with the relevant values at
runtime and continually created with new values and destroyed if not needed
anymore. Please see:
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&ved=0CFUQFjAE&url=http%3A%2F%2Fwww.oracle.com%2Ftechnetwork%2Fjava%2Fjavase%2Fmemorymanagement-whitepaper-150215.pdf&ei=x9m7UKC_O4aAiQe11YHABQ&usg=AFQjCNFSYblAnBZ2obiu7mm3BpKhIUX07w
or
http://www.oracle.com/technetwork/java/javase/tech/vmoptions-jsp-140102.html
for a detailed description.
You might as well start with a decent perm size.
-XX:PermSize=96m
-server has implicitly a MaxPermSpace=64m, if you do not change it.
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.n6.nabble.com/OutOfMemoryError-for-geoserver-2-2-1-tp5019827p5020208.html
