I am currently trialling GeoServer and have a bunch of Image Pyramids
configured on GeoServer 2.5 beta on Windows. Occasionally, I got the
following error:
at
org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1301)
... 119 more
Caused by: java.lang.OutOfMemoryError: Map failed
at sun.nio.ch.FileChannelImpl.map0(Native Method)
... 133 more
I am running on a 32-bit JVM with ImageIO Native installed. I have the
full stack below (it is long!)
After some research, I found this issue:
http://jira.codehaus.org/browse/GEOS-4268
Is it likely that the problem which I am having is because the Image
Pyramid plugin uses Shapefiles, but does not expose the "Use memory
mapped buffers (Disable on Windows)" parameter on the store? Or is there
something else going on?
Thanks
Mark
2014-02-20 15:53:17,619 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the
fast path
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:331)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:509)
at org.geoserver.wms.GetMap.run(GetMap.java:253)
at org.geoserver.wms.GetMap.run(GetMap.java:124)
at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
at sun.reflect.GeneratedMethodAccessor158.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at
org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:79)
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
at
at
org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy66.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor157.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at
at
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: org.geoserver.platform.ServiceException:
org.geotools.data.DataSourceException: Unable to create this mosaic
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:898)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:329)
... 105 more
Caused by: org.geotools.data.DataSourceException: Unable to create this
mosaic
at
org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1352)
at
org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:1193)
at
org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:1159)
at
org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1125)
at
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:629)
at
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:608)
at
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:542)
at
org.geotools.gce.imagepyramid.ImagePyramidReader.loadRequestedTiles(ImagePyramidReader.java:494)
at
org.geotools.gce.imagepyramid.ImagePyramidReader.loadTiles(ImagePyramidReader.java:434)
at
org.geotools.gce.imagepyramid.ImagePyramidReader.read(ImagePyramidReader.java:373)
at
org.geotools.coverage.grid.io.AbstractGridCoverage2DReader.read(AbstractGridCoverage2DReader.java:147)
at
org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:140)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutputFormat.java:1296)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:861)
... 106 more
Caused by: java.io.IOException: Map failed
at sun.nio.ch.FileChannelImpl.map(Unknown Source)
at org.geotools.data.shapefile.files.ShpFiles.map(ShpFiles.java:929)
at
org.geotools.data.shapefile.files.FileChannelDecorator.map(FileChannelDecorator.java:81)
at
org.geotools.data.shapefile.shp.ShapefileReader.init(ShapefileReader.java:325)
at
org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:266)
at
org.geotools.data.shapefile.ShapefileSetManager.openShapeReader(ShapefileSetManager.java:51)
at
org.geotools.data.shapefile.ShapefileFeatureSource.getReaderInternal(ShapefileFeatureSource.java:263)
at
org.geotools.data.shapefile.ShapefileFeatureStore.getReaderInternal(ShapefileFeatureStore.java:126)
at
org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:563)
at
org.geotools.data.store.ContentFeatureSource.accepts(ContentFeatureSource.java:686)
at
org.geotools.data.store.ContentFeatureCollection.accepts(ContentFeatureCollection.java:121)
at
org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.getGranuleDescriptors(CachingDataStoreGranuleCatalog.java:158)
at
org.geotools.gce.imagemosaic.RasterManager.getGranuleDescriptors(RasterManager.java:1135)
at
... 119 more
... 133 more
Ciao Mark,
I am going to check on this right now.
I believe the mapping parameter is not exposed atm for mosaics and pyramids by default and as such it should not
use memory mapping. I am opening a JIRA for this :
https://jira.codehaus.org/browse/GEOT-4712
An alternative for the time being would be to use a datastore.properties like the one attached that you can put in the mosaic directory to control how the shapefile is built more finely.
datastore.properties (289 Bytes)
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Fri, Feb 21, 2014 at 6:28 AM, Mark Grantham <mark@anonymised.com> wrote:
following error:
at
… 119 more
… 133 more
Pyramid plugin uses Shapefiles, but does not expose the “Use memory
mapped buffers (Disable on Windows)” parameter on the store? Or is there
Thanks
Mark
fast path
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 105 more
mosaic
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 106 more
at
at
at
org.geotools.data.shapefile.shp.ShapefileReader.(ShapefileReader.java:266)
at
at
at
at
at
at
at
at
at
… 119 more
… 133 more
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Dear Mark,
a tentative fix is in for 2.4.x. You should be able to grab a nightly today for testing.
Simone Giannecchini
@simogeo
Founder/Director
On Tue, Feb 25, 2014 at 1:23 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Mark,
Simone Giannecchini
@simogeo
Founder/Director
following error:
at
… 119 more
… 133 more
Thanks
Mark
fast path
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 105 more
mosaic
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 106 more
at
at
at
at
at
at
at
at
at
at
at
at
… 119 more
… 133 more
