[Geoserver-users] Output error on KML
I have a shapefile that I’m serving as KML to Google Earth. If I try to view the whole shapefile (a county’s worth of parcels) I get the below error. I have a similar parcel base from a smaller county that works fine. I suspect that either there’s something invalid about the shapefile or it has too many features (~90K). Does the error report tip anyone off? There’s the warning about holes in the polygon(s), but is that what is doing it?
76369920 [INFO] org.vfny.geoserver.servlets.AbstractService - Looking for configured service responses’ strategy
76369920 [INFO] org.vfny.geoserver.servlets.AbstractService - Looking for configured service strategy PARTIAL-BUFFER
76369920 [INFO] org.vfny.geoserver.servlets.AbstractService - Using service strategy class org.vfny.geoserver.servlets.PartialBufferStrategy
76369920 [INFO] org.vfny.geoserver.servlets.AbstractService - Set buffer size to 50
76369922 [INFO] org.vfny.geoserver.wms.requests.GetMapKvpReader - Set KMScore: 40
76369922 [INFO] org.vfny.geoserver.servlets.AbstractService - handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
76371877 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only one hole in this polygon record
76380493 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only one hole in this polygon record
76380500 [INFO] org.vfny.geoserver.wms.responses.map.kml.EncodeKML - Layer () rendered with KMZ raster output.
76384910 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only one hole in this polygon record
76389746 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only one hole in this polygon record
76390055 [INFO] org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer - aborting KMZ encoder
76390056 [INFO] org.vfny.geoserver.servlets.PartialBufferStrategy - OutputStream was successfully aborted.
76390056 [INFO] org.vfny.geoserver.servlets.AbstractService - Had an undefined error: null
76390057 [INFO] org.vfny.geoserver.servlets.AbstractService - EOFException(java.net.SocketException: Connection reset)
at org.mortbay.http.BufferedOutputStream.flush(BufferedOutputStream.java:195)
at org.mortbay.http.ChunkingOutputStream.flush(ChunkingOutputStream.java:67)
at org.mortbay.util.ByteBufferOutputStream.ensureSpareCapacity(ByteBufferOutputStream.java:342)
at org.mortbay.util.ByteBufferOutputStream.write(ByteBufferOutputStream.java:182)
at org.mortbay.http.BufferedOutputStream.write(BufferedOutputStream.java:135)
at org.mortbay.http.HttpOutputStream.write(HttpOutputStream.java:442)
at org.mortbay.jetty.servlet.ServletOut.write(ServletOut.java:42)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:66)
at java.io.BufferedOutputStream.write(BufferedOutputStream.java:79)
at org.vfny.geoserver.util.PartialBufferedOutputStream.write(PartialBufferedOutputStream.java:147)
at java.io.OutputStream.write(OutputStream.java:99)
at java.util.zip.DeflaterOutputStream.deflate(DeflaterOutputStream.java:156)
at java.util.zip.DeflaterOutputStream.write(DeflaterOutputStream.java:114)
at java.util.zip.ZipOutputStream.write(ZipOutputStream.java:260)
at javax.imageio.stream.MemoryCache.writeToStream(MemoryCache.java:148)
at javax.imageio.stream.MemoryCacheImageOutputStream.flushBefore(MemoryCacheImageOutputStream.java:171)
at javax.imageio.stream.ImageInputStreamImpl.flush(ImageInputStreamImpl.java:801)
at org.vfny.geoserver.wms.responses.map.kml.EncodeKML.writeImages(EncodeKML.java:477)
at org.vfny.geoserver.wms.responses.map.kml.EncodeKML.encodeKMZ(EncodeKML.java:173)
at org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer.writeTo(KMZMapProducer.java:112)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:258)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:527)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:279)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.vfny.geoserver.wms.servlets.WmsDispatcher.doResponse(WmsDispatcher.java:156)
at org.vfny.geoserver.wms.servlets.WmsDispatcher.doGet(WmsDispatcher.java:115)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
at org.mortbay.http.HttpServer.service(HttpServer.java:879)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
14:19:08.127 WARN!! Exception for /geoserver/wms?service=WMS&request=GetMap&format=application/vnd.google-earth.kmz+XML&width=1024&height=1024&srs=EPSG:4326&layers=topp:parcelsha&styles=parcels_style&KMScore=40&KMAttr=true&BBOX=-122.6968406098604,40.40032994014587,-122.1854684472549,40.74423873451695
java.lang.IllegalStateException
at org.mortbay.jetty.servlet.ServletHttpResponse.getWriter(ServletHttpResponse.java:540)
at org.vfny.geoserver.servlets.AbstractService.send(AbstractService.java:729)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:788)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:769)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:538)
n
Marc Pfister
Geospatial Data Manager
ENPLAN
mpfister@anonymised.com647…
530/221-0440 x108
530/221-6963 Fax
Hmm... without knowing much about this issue I'd consider the io side
instead of the polygon holes.
Can you try increase the partial buffer size, or change the buffer
strategy?
This:
and the fact that the buffer strategy is visible in the stack trace too
makes me wonder if there's something wrong in that class.
Best regards
Andrea Aime
I get the feeling that it is dieing in the renderer, and then the error isn't being reported properly.
From the trace the KML has handed off control to the streaming renderer, and in there it dies. But the partial buffer isn't handling the error well, or that the KML code gobbles it.
You can turn logging to 'verbose' and set the level to 'finer' to get a more detailed stack trace. And we will be able to help a bit better.
Brent Owens
(The Open Planning Project)
strategy?
This:
Best regards
Andrea Aime
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
-----Original Message-----
From: Brent Owens [mailto:brentowens@anonymised.com]
Sent: Saturday, August 26, 2006 9:42 AM
To: Marc Pfister
Cc: Andrea Aime; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Output error on KML
error
a
Here's the more detailed logging:
161662 [FINE] org.vfny.geoserver.util.requests.readers.KvpRequestReader
- clean request is
rcels_style&KMScore=40&KMAttr=true&BBOX=-123.7688681635021,40.0244315116
8946,-121.518702432977,41.40645369104929
161663 [FINE] org.vfny.geoserver.util.requests.readers.KvpRequestReader
- returning parsed {SRS=EPSG:4326,
BBOX=-123.7688681635021,40.02443151168946,-121.518702432977,41.406453691
04929, LAYERS=topp:parcelsha, KMATTR=true, HEIGHT=1024, REQUEST=GetMap,
STYLES=parcels_style, KMSCORE=40, WIDTH=1024,
FORMAT=application/vnd.google-earth.kmz XML, SERVICE=WMS}
161663 [FINER]
org.vfny.geoserver.util.requests.readers.DispatcherKvpReader -
dispatcher got request GetMap
161663 [FINER] org.vfny.geoserver.wms.servlets.WmsDispatcher - req_type
is 7
161663 [INFO] org.vfny.geoserver.servlets.AbstractService - Looking for
configured service responses' strategy
161664 [FINE] org.vfny.geoserver.servlets.AbstractService - verifying
configured strategy
161664 [INFO] org.vfny.geoserver.servlets.AbstractService - Using
161664 [INFO] org.vfny.geoserver.servlets.AbstractService - Set buffer
size to 50
161664 [FINE] org.vfny.geoserver.servlets.AbstractService - reading
request:
_style&KMScore=40&KMAttr=true&BBOX=-123.7688681635021,40.02443151168946,
161665 [FINE] org.vfny.geoserver.global.Data - getting type
topp:parcelsha
161665 [FINER] org.vfny.geoserver.global.DataStoreInfo - in string url
161666 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
161666 [FINE] org.vfny.geoserver.wms.requests.GetMapKvpReader -
establishing parcels_style style for topp:parcelsha
161668 [INFO] org.vfny.geoserver.wms.requests.GetMapKvpReader - Set
KMScore: 40
161669 [FINER] org.vfny.geoserver.servlets.AbstractService -
serviceRequest provided with HttpServletRequest: /geoserver+/wms+null
GET
&styles=parcels_style&KMScore=40&KMAttr=true&BBOX=-123.7688681635021,40.
02443151168946,-121.518702432977,41.40645369104929 HTTP/1.1
Via: 1.0 PDCRAQ
User-Agent: kh_lt/LT4.0.1565
Host: 192.168.16.23:8080
Accept: text/plain, text/html, text/xml,
text/xml-external-parsed-entity, application/octet-stream,
application/vnd.google-earth.kml+xml, application/vnd.google-earth.kmz,
image/*
Cache-Control: no-cache, no-store
Pragma: no-cache
Connection: keep-alive
161669 [INFO] org.vfny.geoserver.servlets.AbstractService - handling
161669 [FINE] org.vfny.geoserver.servlets.AbstractService - strategy is:
org.vfny.geoserver.servlets.PartialBufferStrategy@anonymised.com
161669 [FINER] org.vfny.geoserver.servlets.AbstractService - executing
request
161670 [FINER] org.vfny.geoserver.wms.responses.GetMapResponse - request
format is application/vnd.google-earth.kmz XML
161671 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - setting
up map
161671 [FINER] org.vfny.geoserver.global.DataStoreInfo - in string url
161673 [FINER] org.vfny.geoserver.global.DataStoreInfo - in string url
161673 [FINER] org.vfny.geoserver.servlets.AbstractService - execution
succeed
161673 [FINER] org.vfny.geoserver.servlets.AbstractService - strategy
output is: org.vfny.geoserver.util.PartialBufferedOutputStream
161674 [FINE] org.vfny.geoserver.servlets.AbstractService - mime type
is: application/vnd.google-earth.kmz
161674 [FINER] org.vfny.geoserver.wms.responses.GetMapResponse -
returning content encoding null
161675 [FINER] org.vfny.geoserver.wms.responses.GetMapResponse - asking
delegate for write to
org.vfny.geoserver.util.PartialBufferedOutputStream@anonymised.com
161675 [FINER] ExpressionAttribute - ENTRY the_geom
161677 [FINER] org.geotools.data.shapefile.Lock - Start Read Lock:main-3
has 1 locks
161681 [FINER] org.geotools.data.shapefile.Lock - Start Read Lock:main-3
has 2 locks
163811 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
169500 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
171962 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
171962 [FINER] org.geotools.data.shapefile.Lock - unlock Read:main-3 has
1 locks
171969 [INFO] org.vfny.geoserver.wms.responses.map.kml.EncodeKML - Layer
171969 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
171970 [FINER] org.geotools.data.shapefile.Lock - Start Read Lock:main-3
has 2 locks
172458 [FINER] org.vfny.geoserver.wms.responses.map.kml.KMLWriter -
applying rule: org.geotools.styling.RuleImpl@anonymised.com
172459 [FINER] org.vfny.geoserver.wms.responses.map.kml.KMLWriter -
processing Symobolizer ...
applying symbolizer org.geotools.styling.PolygonSymbolizerImpl@anonymised.com
172459 [FINER] org.geotools.data.shapefile.Lock - unlock Read:main-3 has
1 locks
172460 [FINE] org.vfny.geoserver.wms.responses.map.kml.KMLWriter -
encoded parcelsha
172460 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
finished writing
172461 [FINER] org.geotools.data.shapefile.Lock - unlock Read:main-3 has
0 locks
172461 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
setting up 1024x1024 image
172587 [FINE] org.vfny.geoserver.wms.responses.map.kml.EncodeKML -
setting to transparent
172607 [FINE] org.geotools.renderer.lite.StreamingRenderer - Affine
Transform is AffineTransform[[455.0775910008342, 0.0,
56324.438364746384], [0.0, -740.943246275776, 30679.832214613652]]
172609 [FINER] org.geotools.resources.i18n.Vocabulary_en - Loaded
resources for English from bundle "org.geotools.resources.i18n".
172611 [FINER] org.geotools.resources.i18n.Errors_en - Loaded resources
172613 [FINER] org.geotools.resources.i18n.Logging_en - Loaded resources
172622 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
172622 [FINE] org.geotools.renderer.lite.StreamingRenderer - processing
1 stylers for parcelsha
172623 [FINE] org.geotools.renderer.lite.StreamingRenderer - creating
rules for scale denominator- 597810.7039098771
172623 [FINER] ExpressionAttribute - ENTRY the_geom
172624 [FINE]
org.geotools.data.shapefile.indexed.IndexedShapefileDataStore - The DBF
file won't be opened since no attributes will be read from it
172624 [FINER] org.geotools.data.shapefile.Lock - Start Read Lock:main-3
has 1 locks
172903 [FINER] org.geotools.renderer.style.SLDStyleFactory - Setting
fill: java.awt.Color[r=255,g=255,b=255]
174124 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
177565 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
179409 [WARNING] org.geotools.data.shapefile.shp.PolygonHandler - only
179410 [FINER] org.geotools.data.shapefile.Lock - unlock Read:main-3 has
0 locks
179412 [FINE] org.geotools.renderer.lite.StreamingRenderer - Style cache
hit ratio: 0.9999884900035682 , hits 86880, requests 86881
179674 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - asking
delegate for aborting the process
179674 [FINE] org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer -
aborting KMZ map response
179675 [INFO] org.vfny.geoserver.wms.responses.map.kml.KMZMapProducer -
179675 [WARNING] org.vfny.geoserver.servlets.PartialBufferStrategy -
OutputStream could not be aborted in time. An error has occurred and
could not be sent to the user.
>> I have a shapefile that I'm serving as KML to Google Earth. If I
try to
>> view the whole shapefile (a county's worth of parcels) I get the
below
works
>> fine. I suspect that either there's something invalid about the
tip
>> anyone off? There's the warning about holes in the polygon(s), but
is
side
> strategy?
> This:
Looking
buffer
>> size to 50
too
> Best regards
> Andrea Aime
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
Could you set Config -> Server -> Verbose Exceptions to 'true'? That may get the proper error returning (will use a full buffer instead of a partial one).
The other question is does it work with normal WMS rendering? Like can you view it in the 'map preview' area of Demo? That might help... Unfortunately even this newer log doesn't have enough information :frowning:
Chris
To: Marc Pfister
error
a
- clean request is
161663 [FINER]
is 7
configured strategy
size to 50
request:
topp:parcelsha
KMScore: 40
GET
Via: 1.0 PDCRAQ
image/*
Pragma: no-cache
request
up map
succeed
has 1 locks
has 2 locks
1 locks
has 2 locks
1 locks
encoded parcelsha
finished writing
0 locks
172624 [FINE]
has 1 locks
0 locks
try to
below
works
tip
is
side
strategy?
This:
Looking
buffer
size to 50
too
Best regards
Andrea Aime
Marc Pfister
ENPLAN
530/221-0440 x108
530/221-6963 Fax
!DSPAM:1003,44f3612f77471995013331!
Chris Holmes
http://topp.openplans.org
