[Geoserver-users] Output large images
I want to export large images with Geoserver, e.g. a 10.000x10.000 Tif. Is
that possible ? Using a WMS request results in an error ("
java.lang.OutOfMemoryError: Java heap space ")
Is there a Geoserver command line tool to generate images, similar like
Mapserver's shp2img ?
Thanks a lot for your help !
Harry Schmidt
View this message in context: http://www.nabble.com/Output-large-images-tp17340853p17340853.html
HarryS ha scritto:
Possible it is, but you'll have to give GeoServer enough memory to
perform the operation. In particular, you need at least 10.000x10.000x4 = ~400MB, and to serve just one of those at a time.
Try starting GeoServer by giving its java virtual machine the -Xmx512m
parameter, that should allow you to generate that big image
Nope, we don't have such a thing, nor one is planned afaik.
Thanks a lot Andrea,
-Xmx1024m
helped to generate a 10.000x10.000 image.
Harry
aaime wrote:
HarryS ha scritto:
Is
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Output-large-images-tp17340853p17342989.html
Hi Harry,
I just wanted to add, that I recently produced overall about 10000 images with different sizes from 4000x4000 to 6000x6000 px with Geoserver WMS without any problems. I have also produced up to 20000 px per side images. Actually I have a pdf plotter application from which I have plotted pdfs’ up to 2m x 2m with 300 dpi resolution. The origin is geoserver. Works nice.
mika
HarryS kirjoitti:
Thanks Mika,
that is good to know.
Harry
Lehtonen, Mika wrote:
Hi Harry,
have plotted pdfs' up to 2m x 2m with 300 dpi resolution. The origin is
mika
HarryS kirjoitti:
-Xmx1024m
Harry
aaime wrote:
HarryS ha scritto:
Is
View this message in context: http://www.nabble.com/Output-large-images-tp17340853p17344735.html
