[Geoserver-users] Output PDF
Hi list,
I remembered to have read about PDF support as outputformat in Geoserver.
I tried using application/pdf and it says is not supported. Searching
on the wiki does not return anything interesting and in the mailing
list i can see a company that created this support, but I dont know if
it already available somewhere.
I am using the latest Geoserver.
Any idea?
Javier.
It is in version 1.3.2
just use outputformat=application/pdf
Here's docs on the output formats: http://docs.codehaus.org/display/GEOSDOC/Output+Formats
Brent Owens
(The Open Planning Project)
Javier de la Torre wrote:
Hi list,
Any idea?
Javier.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Uhmm...
I am using it in a WMS request and instead of outputformat I use
format, but I have tried with both. I still get a message saying that
this is not supported. Look:
http://synthesys.csic.es:8080/geoserver/wms?&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=tdwg:world_base,tdwg:world_adm0,tdwg:world_lb,tdwg:richness_by_c_square_05,tdwg:richness_by_c_square_01,tdwg:biorecord_locations&STYLES=&FORMAT=application/pdf&BGCOLOR=0xFFFFFF&SRS=EPSG:4326&BBOX=39.79248046875,-27.35225293806384,57.37060546875,-19.29040563949799&WIDTH=800&HEIGHT=400&reaspect=false&SLD=http%3A%2F%2Fsynthesys.csic.es%2FSLD%2FSynthesys_for_print.sld.php%3FzoomLevel%3D6
Javier.
Brent Owens
> Hi list,
> Any idea?
> Javier.
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Sorry, I meant "format=..."
I've tested it on several 1.3.2 installations here and remotely and the pdf format is supported, so I'm not sure what's going wrong on your end.
Brent Owens
Uhmm...
Javier.
Brent Owens
> Hi list,
> Any idea?
> Javier.
Uhmmm wired...
Does it have anything to do that I am storing my configuration and
data in an external folder and that this was the same I had for 1.3.1?
I mean, do you store anything in the data folder related to that?
I checked on the logs and nothing new:
Jul 11, 2006 8:50:24 PM org.vfny.geoserver.servlets.AbstractService doService
INFO: handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
FINE: strategy is: org.vfny.geoserver.servlets.PartialBufferStrategy@anonymised.com
Jul 11, 2006 8:50:24 PM org.vfny.geoserver.ServiceException <init>
FINE: There is no support for creating maps in application/pdf format
WARNING: service exception while executing request:
cause: There is no support for creating maps in application/pdf format
Brent Owens
> Uhmm...
> Javier.
>> Brent Owens
>> > Hi list,
>> Geoserver.
>> > Any idea?
>> > Javier.
>> security?
>> job easier
>> Geronimo
>> > _______________________________________________
Very odd. It's not reported in the capabilities document. But it says 1.3.2. It shouldn't matter with the external configuration. But it sounds like it's picking up an old jar instead of the new one. Could you check to see if there's a jar called: itext-1.3.6.jar in your geoserver/WEB-INF/lib directory?
Uhmmm wired...
Brent Owens
Uhmm...
Javier.
Brent Owens
Hi list,
Geoserver.
Any idea?
Javier.
security?
job easier
Geronimo
!DSPAM:1003,44b3f469243821804284693!
Chris Holmes
http://topp.openplans.org
Yes, there is.
> Uhmmm wired...
>> Brent Owens
>>> Uhmm...
>>> Javier.
>>>> Brent Owens
>>>>> Hi list,
>>>> Geoserver.
>>>>> Any idea?
>>>>> Javier.
>>>> security?
>>>> job easier
>>>> Geronimo
Chris Holmes
