[Geoserver-users] override on google earth
when i override my data on google earth, i see a shift of 23m on easting coordinate and 7-8m on northing coordinate, even there are the right parameters towgs84 in the source crs.
why google earth is deforming the map?
thanks for details on that
What is the source projection of your data? And just to be certain, you are viewing your data in google earth? Or overlaying on top of google satellite data?
Do you notice the same shift if you use other clients and reproject?
why google earth is deforming the map? thanks for details on that
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Geoserver-users mailing list
!DSPAM:4007,47ffaa15163102092453641!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
