Ciao Filippo,
a few suggestions/questions:
- I would use release 1.6.4, the latest and greatest (see [2])
- Can you provide some details about platform/java version you are working on?
- You mention you are using the oracle plugin, but the WMS request you
report seems to be against the states shapefile, hence oracle is not
involved here. Am I right or you have ingested the states shapefile
into oracle?
- Could you check the logs for the server and report any error message
that you can find for this request? (You can use pastebin to report
the error).
Ciao,
Simone.
[2] http://geoserver.org/display/GEOS/Stable
On Mon, Jun 30, 2008 at 11:41 AM, Snamprogetti
<filippo.bultrighini@anonymised.com> wrote:
I'm using version 1.6.3 (windows installer) with Oracle plugin. What version
do you suggest?
That request was suggested by the documentation itself so i guess it's
complete. However i also tried and failed with other requests, such as:
http://localhost:8090/geoserver/wms?service=WMS&request=GetMap&format=image/png&width=800&height=600&srs=EPSG:4326&layers=topp:states&styles=polygon&bbox=-125,25,-67,50
Alessio Fabiani wrote:
which version of GeoServer are you using? I kindly suggest to not use the
trunk version in this moment, since many there are a lot of changes going
on.
Moreover the request seems to me a bit uncomplete, you need also other
parameters like the service, the version and the output format at least.
View this message in context: http://www.nabble.com/ows-Exception-tp18156021p18191980.html
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
