[Geoserver-users] Padding set to 0 instead of No Data when reprojecting
I have some Tiff files in EPSG:26915 (UTM 15 N) which I am requesting via WMS in EPSG:4326 to display on a map.
When the image is reprojected, it is rotated and the padding area added to make the image rectangular again has its value set to 0 instead of to the No Data value.
Since my image also has actual values of 0, this means that the new padding which should be set to No Data (and rendered transparent) is instead rendered with a color as though it had data.
This screenshot makes it clear what I mean: Screenshot: http://s31.postimg.org/5f96rqvi3/what_am_i_doing_wrong.png
Has anyone seen this? Am I doing something wrong? I tried searching, but I might not be describing it correctly in my searches. The best I could do was this 7 year old GDAL ticket: https://trac.osgeo.org/gdal/ticket/2724
Michael
Other info that might be relavant:
GeoServer Build Information
Version 2.8.3
Git Revision 1c8c9ba0f74a465c397d46cf19d3b34b95b2fb6e
Build Date 22-Mar-2016 21:12
GeoTools Version 14.3 (rev 2298d56000bef6f526b521a480316ea544c74571)
GeoWebCache Version 1.8.2 (rev 1.8.x/442d5127d1a01942f4c04c8140ade4c4538bb16d)
This is running on Windows Server 2012 (64 bit), but running 32 bit GeoServer and 32 bit java.
My WMS request looks like this:
http://MyServer/geoserver/rabaey-fred/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image/jpeg&TRANSPARENT=true&LAYERS=myLayer&STYLES=rainbowstatic&SRS=EPSG:4326&WIDTH=331&HEIGHT=769&BBOX=MyBBox
The GeoServer log for that request looks like this:
2016-04-22 09:34:37,549 INFO [geoserver.wms] -
Request: getMap
Filters = null
BgColor = java.awt.Color[r=255,g=255,b=255]
SRS = EPSG:4326
Tiled = false
Palette = null
FeatureVersion = null
Styles = [StyleImpl[ name=rainbowstatic]]
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Angle = 0.0
Crs = GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]]
Bbox = SRSEnvelope[MyBbox]
Env = {}
StartIndex = null
CQLFilter = null
RemoteOwsURL = null
ViewParams = null
FormatOptions = {}
FeatureId = null
RemoteOwsType = null
Elevation =
Sld = null
ValidateSchema = false
Interpolations =
Transparent = true
StyleFormat = sld
StyleUrl = null
SldBody = null
TilesOrigin = null
Exceptions = SE_XML
StyleVersion = null
SldVersion = null
StyleBody = null
ScaleMethod = null
Time =
Height = 769
Width = 331
Format = image/png8
Buffer = 0
Filter = null
Request = GetMap
BaseUrl = http://MyServer/geoserver/
RawKvp = {REQUEST=GetMap, FORMAT=image/png8, SRS=EPSG:4326, BBOX=MyBBox, VERSION=1.1.1, STYLES=rainbowstatic, SERVICE=WMS, WIDTH=331, HEIGHT=769, TRANSPARENT=true, LAYERS=MyLayer}
Get = true
RequestCharset = UTF-8
Version = 1.1.1
Gdalinfo reports the following for the source .tiff image:
Driver: GTiff/GeoTIFF
Files: 0-0-62.tiff
Size is 247, 229
Coordinate System is:
PROJCS[“NAD83 / UTM zone 15N”,
GEOGCS[“NAD83”,
DATUM[“North_American_Datum_1983”,
SPHEROID[“GRS 1980”,6378137,298.257222101,
AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY[“EPSG”,“6269”]],
PRIMEM[“Greenwich”,0,
UNIT[“degree”,0.0174532925199433,
AUTHORITY[“EPSG”,“9122”]],
AUTHORITY[“EPSG”,“4269”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,-93],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AXIS[“Easting”,EAST],
AXIS[“Northing”,NORTH],
AUTHORITY[“EPSG”,“26915”]]
Origin = (myOrigin,myOrigin)
Pixel Size = (3.000000000000000,-3.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( xxxxxx.xxx, xxxxxx.xxx) ( xxd x’xx.xx"W, xxdxx’xx.xx"N)
Lower Left ( xxxxxx.xxx, xxxxxx.xxx) ( xxd x’xx.xx"W, xxdxx’xx.xx"N)
Upper Right ( xxxxxx.xxx, xxxxxx.xxx) ( xxd x’xx.xx"W, xxdxx’xx.xx"N)
Lower Right ( xxxxxx.xxx, xxxxxx.xxx) ( xxd x’xx.xx"W, xxdxx’xx.xx"N)
Center ( xxxxxx.xxx, xxxxxx.xxx) ( xxd x’xx.xx"W, xxdxx’xx.xx"N)
Band 1 Block=247x8 Type=Float32, ColorInterp=Gray
NoData Value=1.701410009187828e+038
Hi Michael,
the problem might have been fixed in GeoServer 2.9.x, can you try out the beta2 release?
It’s the latest we have:
http://blog.geoserver.org/2016/04/22/geoserver-2-9-beta2-released/
On Fri, Apr 22, 2016 at 4:44 PM, Michael Moore <stuporglue@anonymised.com…> wrote:
Michael
Version 2.8.3
Request: getMap
Filters = null
SRS = EPSG:4326
Tiled = false
Palette = null
MaxFeatures = null
Angle = 0.0
Env = {}
StartIndex = null
CQLFilter = null
RemoteOwsURL = null
ViewParams = null
FormatOptions = {}
FeatureId = null
Elevation =
Sld = null
Interpolations =
Transparent = true
StyleFormat = sld
StyleUrl = null
SldBody = null
TilesOrigin = null
Exceptions = SE_XML
StyleVersion = null
SldVersion = null
StyleBody = null
ScaleMethod = null
Time =
Height = 769
Width = 331
Format = image/png8
Buffer = 0
Filter = null
Request = GetMap
Get = true
Version = 1.1.1
Files: 0-0-62.tiff
Size is 247, 229
GEOGCS[“NAD83”,
UNIT[“metre”,1,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Will do. Downloading now.
I also found this site: http://www.geo-solutions.it/blog/developers-corner-jai-ext-the-open-source-replacement-for-oracle-jai/
which indicates that “JAI is unable to deal with NoData” – I realized after sending my email that I had forgotten to mention that I do have JAI enabled.
Michael Moore
On Fri, Apr 22, 2016 at 10:05 AM, Andrea Aime <andrea.aime@…1107…> wrote:
Hi Michael,
On Fri, Apr 22, 2016 at 4:44 PM, Michael Moore <stuporglue@anonymised.com> wrote:
Michael
Version 2.8.3
Request: getMap
Filters = null
SRS = EPSG:4326
Tiled = false
Palette = null
MaxFeatures = null
Angle = 0.0
Env = {}
StartIndex = null
CQLFilter = null
RemoteOwsURL = null
ViewParams = null
FormatOptions = {}
FeatureId = null
Elevation =
Sld = null
Interpolations =
Transparent = true
StyleFormat = sld
StyleUrl = null
SldBody = null
TilesOrigin = null
Exceptions = SE_XML
StyleVersion = null
SldVersion = null
StyleBody = null
ScaleMethod = null
Time =
Height = 769
Width = 331
Format = image/png8
Buffer = 0
Filter = null
Request = GetMap
Get = true
Version = 1.1.1
Files: 0-0-62.tiff
Size is 247, 229
GEOGCS[“NAD83”,
UNIT[“metre”,1,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Apr 22, 2016 at 5:12 PM, Michael Moore <stuporglue@anonymised.com> wrote:
Thanks
which indicates that "JAI is unable to deal with NoData" -- I realized
enabled.
JAI cannot really be avoided, by "jai enabled" do you mean you have native
JAI Installed?
If so, and 2.9-beta2 does not fix the issue, I'd also try to remove native
JAI.
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Apr 22, 2016 at 10:14 AM, Andrea Aime <andrea.aime@anonymised.com>
Thanks
enabled.
JAI Installed?
JAI.
OK, I tried 2.9-beta2 on both my Mac and on Windows, and I tried it with
and without JAI-EXT and it still doesn't seem to be working quite right.
http://s31.postimg.org/f4dtqsryj/Issue_in_2_9_beta2.png
Without JAI-EXT it renders the same way as before.
With JAI-EXT it seems to convert all of the NoData cells to have a value of
zero too, but only for rendering. GetFeatureInfo requests still return the
appropriate value -- 0 in the zero areas, and 1.701410009187828E38 in the
NoData areas.
With the following test SLD:
                        <sld:ColorMap type="values">
                           <sld:ColorMapEntry color="#000000" label=" "
opacity="1.0" quantity="0"/> <!-- 0 -->
                        </sld:ColorMap>
Both the NoData and 0-value cells are rendered as black.
Any other things I could try?
Michael
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Michael,
at this point I’d open a ticket at https://osgeo-org.atlassian.net/projects/GEOS/summary
attaching data, style and request to reproduce the issue
On Fri, Apr 22, 2016 at 10:39 PM, Michael Moore <stuporglue@anonymised.com> wrote:
On Fri, Apr 22, 2016 at 10:14 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
OK, I tried 2.9-beta2 on both my Mac and on Windows, and I tried it with and without JAI-EXT and it still doesn’t seem to be working quite right.
With JAI-EXT it seems to convert all of the NoData cells to have a value of zero too, but only for rendering. GetFeatureInfo requests still return the appropriate value – 0 in the zero areas, and 1.701410009187828E38 in the NoData areas.
<sld:ColorMap type=“values”>
<sld:ColorMapEntry color=“#000000” label=" " opacity=“1.0” quantity=“0”/>
</sld:ColorMap>
Michael
Thanks
JAI cannot really be avoided, by “jai enabled” do you mean you have native JAI Installed?
If so, and 2.9-beta2 does not fix the issue, I’d also try to remove native JAI.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
