[Geoserver-users] Pass SQL View Param in GetMap POST request
Hi all
When using a parametrised SQL View I realise that key:value pairs can
be passed in a GetMap GET request. However, I am confronted with a
scenario in which I need to pass a geometry (e.g. GML encoded) and the
idea of trying to fit/format it in a URL concerns me.
So, please does anyone know if there is there a way to pass the SQL
View key/values in a GetMap POST request? I could not easily find any
example in the documentation or around the web...
Kind regards
Peter
Hi Peter,
you cannot pass sql view parameters inside the post body, but have you tried putting them anyways
in the url (just those parameters)? I believe at some point we had the ability to handle mixed requests
On Wed, Jul 20, 2016 at 6:49 PM, Peter Devoy <peter@anonymised.com> wrote:
Hi all
example in the documentation or around the web…
Kind regards
Peter
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports.http://sdm.link/zohodev2dev
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea
Thanks for confirming that for me. It is a nice idea but
unfortunately because I am looking at passing geometries of an unknown
size I am not sure I could do it in a standards compliant way (special
characters, string length).
I think I will just write the geometry to a database, return the ID
and pass that in instead :slight_smile:
All the best
Peter
3XE
P: 01326 567155
M: 07770 693662
A: 3XE Ltd
Tremough Innovation Centre
PENRYN
TR10 9TA
3XE Ltd · Registered in England and Wales · 9356871
On 20 July 2016 at 18:29, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Peter,
Hi all
Kind regards
Peter
traffic
are
planning
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Peter,
there is also the possibility to make a GET like request by submitting a form.
Just so you know, not sure it’s going to help your specific case (even POST requests
have a size limit, normally configurable in the web container)
On Wed, Jul 20, 2016 at 8:06 PM, Peter Devoy <peter@anonymised.com…7739…> wrote:
Hi Andrea
All the best
Peter
3XE
P: 01326 567155
M: 07770 693662
A: 3XE Ltd
PENRYN
TR10 9TA
Hi Peter,
Hi all
Kind regards
Peter
traffic
are
planning
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
Ing. Andrea Aime
@geowolf
Technical Lead
