[Geoserver-users] PC Install 1.7.2
Hi-
I've been running into a problem installing geoserver on a PC (Win Xp). I tried running the binary install (%GEOSERVER_HOME%/startup), but when I try to run startup.bat I get an error stating that -DGEOSERVER_DATA_DIR is not recognized as a command. I then tried downloading the Windows installer, but the installer kept returning that it could not access any of the necessary files (startup, shutdown, any of the jetty configurations, etc).
Is there something simple that I'm not doing here? I feel like I'm missing a step, but I don't know what it would be.
Thanks-
Seth Stradling
Hi Seth. I'm running 1.7.2 from the Windows Installer (XP), and I had no troubles at all. How far do you get in the process? Can you send a screenshot of the error?
Mike Pumphrey
OpenGeo - http://opengeo.org
Seth Stradling wrote:
Hi-
I've been running into a problem installing geoserver on a PC (Win Xp). I tried running the binary install (%GEOSERVER_HOME%/startup), but when I try to run startup.bat I get an error stating that - DGEOSERVER_DATA_DIR is not recognized as a command. I then tried downloading the Windows installer, but the installer kept returning that it could not access any of the necessary files (startup, shutdown, any of the jetty configurations, etc).
Thanks-
Seth Stradling
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-users mailing list
Could it be a problem with having or not administrator rights on the computer ?
Best regards,
Alexandre Gacon
On Mon, Feb 2, 2009 at 5:37 PM, Mike Pumphrey <mike@anonymised.com> wrote:
Hi Seth. I’m running 1.7.2 from the Windows Installer (XP), and I had
Mike Pumphrey
Hi-
I’ve been running into a problem installing geoserver on a PC (Win
Is there something simple that I’m not doing here? I feel like I’m
missing a step, but I don’t know what it would be.
Thanks-
Seth Stradling
Hi-
Sounds a lot like the issue reported here:
http://jira.codehaus.org/browse/GEOS-2591
If it's that one, just set JAVA_HOME before running the startup
script, something like:
set JAVA_HOME="c:\program files\java\jdk_1.6.0_10"
(adapt to your system as needed). If that works, you can either embed
the above command inside the startup.bat itself, or set JAVA_HOME
as system wide environment variable (how to do so depends on the
windows version you're using).
I am a complete newbie to GeoServer and I struggle a lot, so I know it is a little crazy that I try to answer any of the questions here… still, even without understanding much I have a suggestion… yesterday I installed geoserver 1.7.2 and I couldnt access it (i got a “resource unavailable message”) until I created a setenv.bat file and saved it in Apache’s bin directory following these instructions:
http://geoserver.org/display/GEOSDOC/Tomcat+-+data_dir+environment+variables
Salût,
** Virginia
Date: Mon, 2 Feb 2009 17:51:32 +0100
To: seths@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] PC Install 1.7.2
Hi-
If it’s that one, just set JAVA_HOME before running the startup
set JAVA_HOME=“c:\program files\java\jdk_1.6.0_10”
windows version you’re using).
Geoserver-users@anonymised.com.sourceforge.net
Invite your mail contacts to join your friends list with Windows Live Spaces. It’s easy! Try it!
