Hi
I have some trouble with the pdf output and unfilled polygons. Using gif- or png-files for filling and setting transparent to true is leading to unfilled polygons sometimes:
http://www.sogis1.so.ch:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=application/pdf&LAYERS=Ortsplan&TRANSPARENT=true&BBOX=606907.6486276796,227596.13479275,607102.1111716905,227744.47298518&WIDTH=8610&HEIGHT=6560&SRS=EPSG:21781
Changing to transparent=false and everything is ok:
http://www.sogis1.so.ch:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=application/pdf&LAYERS=Ortsplan&TRANSPARENT=false&BBOX=606907.6486276796,227596.13479275,607102.1111716905,227744.47298518&WIDTH=8610&HEIGHT=6560&SRS=EPSG:21781
It gets a bit stranger with other layers (no polygons are filled):
http://www.sogis1.so.ch:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=application/pdf&LAYERS=av_pfdgb&TRANSPARENT=true&BBOX=606907.6486276796,227596.13479275,607102.1111716905,227744.47298518&WIDTH=8610&HEIGHT=6560&SRS=EPSG:21781
This example should look like this:
http://www.sogis1.so.ch:8080/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=application/pdf&LAYERS=av_pfdgb&TRANSPARENT=false&BBOX=606907.6486276796,227596.13479275,607102.1111716905,227744.47298518&WIDTH=8610&HEIGHT=6560&SRS=EPSG:21781
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
