Hi
I’m a little bit confused about the pdf output of raster data. If you try the sf:dem example and decrease the upper y axis value from 4928000.0 to 4924000.0 you get a pdf with lots of white space. I would rather expect a distorted image like you would get if you request a png. If you decrease 4924000.0 to 4920000.0 you get a empty pdf. Any ideas? I’m using Geosever 1.6.3.
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Ziegler Stefan ha scritto:
Hi
I'm a little bit confused about the pdf output of raster data. If you try the sf:dem example and decrease the upper y axis value from 4928000.0 to 4924000.0 you get a pdf with lots of white space. I would rather expect a distorted image like you would get if you request a png. If you decrease 4924000.0 to 4920000.0 you get a empty pdf. Any ideas? I'm using Geosever 1.6.3.
I tried with the following:
Unchanged from preview (they do look the same):
http://localhost:8080/geoserver/wms?HEIGHT=552&WIDTH=800&LAYERS=sf%3Adem&STYLES=&SRS=EPSG%3A26713&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=584669.0625,4910773.203125,614340.9375,4931246.796875&bgcolor=0xAAAAAA
http://localhost:8080/geoserver/wms?HEIGHT=552&WIDTH=800&LAYERS=sf%3Adem&STYLES=&SRS=EPSG%3A26713&FORMAT=application/pdf&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=584669.0625,4910773.203125,614340.9375,4931246.796875&bgcolor=0xAAAAAA
Increasing maxy to 4940000 (again the same):
http://localhost:8080/geoserver/wms?HEIGHT=552&WIDTH=800&LAYERS=sf%3Adem&STYLES=&SRS=EPSG%3A26713&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=584669.0625,4910773.203125,614340.9375,4940000&bgcolor=0xAAAAAA
http://localhost:8080/geoserver/wms?HEIGHT=552&WIDTH=800&LAYERS=sf%3Adem&STYLES=&SRS=EPSG%3A26713&FORMAT=application/pdf&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=584669.0625,4910773.203125,614340.9375,4940000&bgcolor=0xAAAAAA
Reducing maxy:
http://localhost:8080/geoserver/wms?HEIGHT=552&WIDTH=800&LAYERS=sf%3Adem&STYLES=&SRS=EPSG%3A26713&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=584669.0625,4910773.203125,614340.9375,4920000&bgcolor=0xAAAAAA
http://localhost:8080/geoserver/wms?HEIGHT=552&WIDTH=800&LAYERS=sf%3Adem&STYLES=&SRS=EPSG%3A26713&FORMAT=application/pdf&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=584669.0625,4910773.203125,614340.9375,4920000&bgcolor=0xAAAAAA
Yes, in this case the coverage is not drawn, but I don't see why...
PDF is generated running exactly the same code as PNG output against
a graphics context provided by iText.... so it seems like a bug in how
iText handles raster drawings (in particular, raster + an affine transform, which is what is happening in the code).
Can you open a jira issue about this?
